Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Lcd tv with in built dvd/cd. can't read disc keeps ejecting it
When i ninsert a dvd or cd into the inbuilt system it says read then no disc and ejects the disc. it worked ok before i moved the tv .could i have disturbed an internal wire or something? if os, is it relatively easy to fix?
  • 90 Answers
Run a cleaning disk through the system -- then try again --- sounds like the unit wont read the disk properly and by moving it -- some dirt or dust may have caused this problem
Posted on Feb 24, 2009
How do you eject the DVD
I you can't do it with the Remote control, you might be able to do it on the TV itself.
I'm not positive about this, but there should be a button on the back outer-edge of the TV that may control the DVD player.
If not, here is a link to Download the manual. Scroll down & click on 'Guides + Info' and then the download link.
http://www.us-appliance.com/pledv1945a.html
PLEDV1945A Proscan 19 LED 720p HDTV with Built in DVD Player
Good luck.
Andrew
Feb 24, 2015 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Cd wont eject out of t_v
Disc loading mechanism fault. Contact any service technician. The mechanism should take out from the TV; either for repair, or replacement. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
Cannot eject dvd from toshiba rc-1900 - remote control is working
I have same problem, the remote does not appear to have a DVD eject, despite having controls for the inbuilt DVD player. There is a button on the tv at the top left hand side, if this is pressed a couple of times in quick succession, the disc will eject.
Feb 26, 2014 | Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
CD stuck in DVD player in tv
I'm sorry that the disc tray is not ejecting. Please check whether you're able to locate a small hole under the tray opening area. If one available, please insert a pin and it will eject manually now..
Dec 18, 2011 | Televison & Video
DVD disc stuck in built in dvd on LG LCD TV/DVD combo
1. Power the set down.
2. Hold the eject button on the drive while you plug it back in and power it back up.
That should eject the drive.
Aug 29, 2011 | LG 32LG40 32 in. LCD HDTV
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
