Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Kitchen Aid Double Convection Oven blows circuit breaker
We have had this unit for three years.  It is the Kitchen Aid Pro Line series.  Works fine until we try to have both ovens at high temperatures, above 400 degrees.  Then it blows the circuit breaker.  I can turn the breaker back on and it works fine with one oven, but not with two. The unit paperwork calls for a 30 amp breaker.  It appears that we have this attached to two 40 amps circuits tied together.
Your thoughts?
  • Anonymous Mar 31, 2014
    this sound goes on for an hour until the oven is cooled. How can I turn it off. It i extremely annoying!
The kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Posted on Jun 13, 2009
Kitchen aid oven
if you put your volt meter leads across the bake element you should be getting 240 volts when its in the bake cycle.
Its sounds like the control board is bad.i suggest you call a local repairman...
Aug 07, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
May 02, 2007 | KitchenAid KEMC378 Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
642 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
