Question about Toshiba e-Studio162D Copier
How to reset maintanance message of sharp-ar 5127
Normaly copier display is green, now it is red color and have message for maintanance,so how to reset this maintanance message ?
  • Toshiba Master
  • 653 Answers
U need to enter stimulation mode:
"C" key->Auto/Text/Photo key->"C"key->Auto/Text/Photo key
*perform above 4 key strokes quicky
Once inside stimulation mode, enter main code "20", then sub code "01" for maintenance counter clear, press "START" key to clear.
Posted on Feb 19, 2009
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
What color is the light suppose to be when my pyle pro pwma600 pa speaker is charging suppose to be green or red?
Hi,normaly the green light says that the battery is fully charged,so if its red it might be that its charging but not fully charged,but saying that if it dose not charge after some time then the red light can mean its not charging,just food for thought,all the best.
Oct 02, 2015 | Cars & Trucks
HARD RESET hp laserjet m175nw ?
Try this:
1- Make sure printer is off.
2- Press and hold Red X and Right Arrow key.
3- Switch printer on (Red X and Right Arrow still pressed down)
The goal is to get the printer display a "Printer Settings Init" message. Release the two buttons when you get this message. If nothing happens, try the procedure over again.
May 14, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
I have a primera signature 4 ink jet CD printer. It will not print and the left green light on top is flashing very fast.
The printer lighting symbol indicators are messages of replaceable resources either paper or ink. usually the printer is expected to perform until a fault displays a logo either green for functionality, pink of resources shortage, and red for power resources insufficiency. Checking on the printer compartments to ascertian the conditions or replaceabel resources paper, ink, or jams due to paper over loads. Computer messages with printers would display the fault. For example, a printer message on the computer either as print job request unsuccessful or requirng software would be observable from the computer screen.
Jan 14, 2011 | Primera Technology Primera SignaturePro CD...
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
What color is the maintanence light on a 93 honda
You should not have a maintenance light, as those appeared on the 1998 model Accords and up. My old 1996 Accord had an indicator in the gauge cluster which showed either green or red. To reset it, if you looked beside the indicator, you would see a slot to put your key in to reset the indicator.
May 19, 2010 | 1993 Honda Accord
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
Toshiba e-Studio162D Copier Logo
1,497 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
