Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
Clutch requires a 3/8 id bearing all ordered parts are 5/16 help
On my poulan p3314 chainsaw the cluch drum and sprocket have a 3/8 id bearing. when I order a clutch drum thay all come in with a 5/16 id bearing how do I get what I need?
  • Anonymous Mar 10, 2009
    cluch will not disenguage
  • 2,176 Answers
Have you tried to order direct from Poulan at Poulanpro.com if not they have a toll free number that you can call to get in contact with one of their dealers and that should get you up and running again.
Posted on Feb 19, 2009
How do you remove a clutch drum on Poulan Pro PP4620AVHD chain saw
YouTube can be a great help with video's of 'how to' do things.
I have attached a video from 'donnyboy73.' I found his video's to be very informative and well put together. The video link is not of your exact saw but is a Poulan and I hope will be helpful to you.
HOW TO Remove Clutch & Sprocket on Poulan 2150 Chainsaw. The same procedure can be applied to many other chainsaws.
http://www.youtube.com/watch?v=zf28-ztoHfg
Oct 17, 2014 | Poulan Garden
Show me how to change clutch on 3314 p
Use a Poulan clutch tool and look at the clutch for the direction to rotate the clutch. There will be an arrow and It should be CCW
Sep 14, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
When I disengage my chain brake to stop the chain it shuts the chain saw off rather than let it idle until I need to engage the chain again.
This is probably an issue with either the clutch spring, or the sprocket bearing, if there is any drag from either of the components it will drag the engine down to a stop when the brake is applied, check the clutc spring if you can pull the shoes out by hand the spring has streched and will require replacment, turn the sprocket around manually, if there is any resistense ( drag on the crank ) then grease the sprocket bearing.
Jan 29, 2011 | Poulan 14" Chainsaw
Chain does not rotate around bar. Chain brake seems to engage/disengage as intended.
With a gloved hand can you manually pull the chain around the bar? if not the chainbrake is still engaged, pull the hand guard fully back to the top handle until you hear the click from the brake mechanism, if the chain does pull around manually then there is a problem with either the cluch or the sprocket, remove the side cover, check the clutch for damage, remove the drive sprocket and check the drive teath are not badly worn allowing the chain to slip within it, replace parts as required.
Jan 21, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I have a Poulan P2316 chain saw. The chain got stuck in a tree. After freeing it, the clutch appears to be locked up. The chain moves freely on the bar when I remove it from the saw. Thanks Alan
Make sure the chain brake isn't set. When you turn the clutch outer drum, does it try to turn the engine as well? If so, try oiling the bearing that allows the outer drum to turn over the inner section, and work the oil into the bearing. If no help, you will need to replace the clutch. It is held to the shaft with left-hand-threads and usually requires a special tool to remove it, plus the upper cylinder needs to be stuffed with starter cord so that the piston cannot rise much above the upper part of the exhaust port while trying to remove the clutch. Don't try to remove it with an impact wrench as that will shear the flywheel key. Hope this helps!
Jul 14, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Am lookin at online photo of Poulin P3314 Type 2 gas chain saw (parts breakdown). Need to install part # *****57931 Assy-oil pump and part # 57924, oil pick up. Can't tell by this breakdown image where...
P3314 Gas Chain Saw Type 2 IPL can be found here:
http://www.ordertree.com/modelinfo/PWE/P3314-Gas-Saw-Type-2/75.P3314-Gas-Saw-Type-2.1.59.1.html
She has an inboard clutch, start here:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Continue with remainder, use this as a guide for the remainder:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.Everyone I have ever removed had a left handed thread (tighten it to loosen it).
The oil pump is behind the actual clutch.
Additional Poulan IPLs can be found here:
Poulan.com
HTH
Lou
Jan 22, 2010 | Poulan Garden
Need to replace drive sprocket on Poulan 2150 chainsaw. Do I need a special tool to remove?
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Nov 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Super25DA old chainsaw from the mid 70's.
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
Oct 01, 2009 | Garden
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
194 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
