Question about Vizio L32 32 in. LCD HDTV
I can't get a TV signal on new 22" VIZIO - Vizio L32 32 in. LCD HDTV
  • 1 more comment
  • tpu_06248 Feb 19, 2009
    Hi. It's a brand new 22" set...not certain of the model #. In setting it up, when in TV mode a display on the blue screen reads, "No Signal". I am however able to view the channels when I'm in HDMI1 mode. Thanks.
  • tpu_06248 Feb 22, 2009
    Marion, thank you very much for posting your solution to my problem...it worked perfectly after I followed your instructions. Thanks again, I very much appreciate it.
    Tony
  • marionbagget May 11, 2010
    You need to indicate the model number and what you are doing/done with the set. Is this a new set ?
  • 718 Answers
If you are getting the "No Signal" message you need to connect an antenna or cable to the antenna input. You also need to go into the menu for your signal source and select ANTENNA or AIR if you are using an antenna OR CABLE if you are using cable.
NEXT YOU WILL HAVE TO SCAN IN YOUR STATIONS !! This is not like the old analog sets that plug in and run.
The instruction manual will give you precise instructions.
Posted on Feb 19, 2009
Vizio tv says no signal
you should be able to do that with the remote by pushing "03"
or with manual buttons in menu under tuning selections , add channel 03
Apr 15, 2014 | Televison & Video
URC 8810 universal codes for VIZIO 22" tv one for all
There is no set-up codes to Vizio brand TV, with this remote control. If you wish to get more, check the site linked here.http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://electronicshelponline.blogspot.com/
Jul 27, 2013 | Vizio VO22L 22 in. LCD TV
No signal
Check your video settings to make sure tv is on tv or catv. catv is for cable. If you have neither, then your tuner is bad.
Jun 18, 2012 | Vizio VA220E 22 Class LCD HDTV - 720p,...
I just bought a m221nv from ebay tv dealer an he said i could jus plug it in in my kitchen, bedrm or ? and watch it via my router cause it has wifi no need connect cable, antenna or anything but i cant get...
The wifi connection will allow you to access content via the Vizio Internet Apps (Netflix for example) but not tv broadcasts.
Your tv can access tv broadcasts (CBS, NBC, FOX, ABC) over the air but w/o an external antenna the signal and therefore the quality will probably be weak.
To access cable/direct tv/fios content you will need to connect the tv via a cable.
Mar 01, 2011 | Vizio M221NV 22 in. HDTV LCD TV
I hooked up my vizio 22" tv up to my laptop
Check the tuner i/o board connector there might be a loose connection from the soccket.
I/O board means input output board, this is where the antenna and audio video input are pack in.It is just inserted at the socket..check whethere the connectors are lock properly
Jan 30, 2011 | Vizio VA220E LCD TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
The tv was on for 2 hours and then just went to a black screen. Unpluged for 10 min and tried again, the picture came back for 5 to10 seconds black and white vertical lines and then to a black screen. The...
The tv have problems with it Tuner incomming Signal board,it have dead componnents on it board.Call for warrenty repair,it the Tuner board it dead.Or return where u purchase it,get a new tv for the replacement.
May 24, 2010 | Vizio VO47L 47 in. LCD TV
Missing plastic base from Vizio 22" LCD TV
Go to ur tv website buy ur part,Type in ur S/N and part.
Sep 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Two tv's in the same room, both vizio's. How can I change it so one remote works for one tv and the other works for that tv. Our tv is a new vizio 22'' flat 1080p
U can't, they both use the same parity. You could put a piece of black electrical tape over the IR receiver in the front of the set so it can't recieve the signal, but when u want to use it by remote you'll have to remove the tape.
Jun 09, 2009 | Vizio VO22L 22 in. LCD TV
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
Vizio L32 32 in. LCD HDTV Logo
317 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
