Question about Acer Aspire 5610-4648 Notebook
Toshiba Satellite M55 laptop has unexpected mouse click operation from time to time.
    President:
  • 2,653 Answers
That's probably a hardware problem. If it's under warranty then follow that route, otherwise it's more trouble than it's worth to fix that problem.
Posted on Feb 20, 2009
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
WHERE CAN I DOWNLOAD THE DRIVER FOR TOSHIBA SATELLITE M55-S3262 FOR FREE
From the Toshiba Technical Support page at http://pcsupport.toshiba.com, click Tech Support Center.
Sep 17, 2010 | Toshiba Satellite M55-S3262 PC Notebook
My computer have a problem in your audio.What drive audio i can install
I believe what you seek is here...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1204306&rpn=PSM53U&modelFilter=M55-S141&selCategory=2756709&selFamily=1073768663#
if you have a problem with accessing that link go here
support.toshiba.com
then click Download, select the proper info for your laptop and it will offer a handy listing of all drivers for the system. :)
Aug 05, 2010 | Toshiba Satellite M55-S141 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Toshiba Satellite M55-S325 PC Notebook outsde case
You definitely need to bring your laptop to the Toshiba shop near you. There they can facilitate the replacement of your laptop's body (casing). It is a critical task to do and I think a Toshiba authorized shop can help you with this. Thanks.
Feb 03, 2010 | Toshiba Satellite M55-S325 Notebook
My mouse on my toshiba satellite M55 S 3512 is not working. I spilt a little water on it a few days before. Quickly turned off my lap top and dried it up. A few hours later when i turned it on..the mouse...
Hello, this is Mike. I'm sorry to tell you that despite being having dried up the water you spilled more than likely left mineral deposits on the circuits in your mouse which cause it to short out and not function. If you are using an external USB mouse I recommend replacing it. If it was the touch pad on the laptop itself I must recommend you attempt to use your warrantee to have it replace or if it has expired I suggest you bring your laptop to a certified technician and have it repaired. I hope this helped you.
Jan 19, 2010 | Toshiba Satellite M55-S3512 Notebook
Typing problem with keyboard
the easy method would be to hook up a USB mouse and disable the touchpad to see if that works. Control Panel -> Mouse (or Printers and other Hardware), then click on the mouse and then click on Advanced or Hardware tab to look at the options. You might be able to have it disable the touchpad when a mouse is present.
Feb 26, 2009 | Toshiba Satellite M55-S329 Notebook
The support site for Toshiba for this product is here
In case you can't use hot linki8ng, here is the raw link : http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1042102&rpn=PSM50U&ct=DL&BV_SessionID=@@@@1083467310.1191223395@@@@&BV_EngineID=ccceaddmdmihhgecgfkceghdgngdgmm.0 Cut and paste that into your browser's address line, and you should be looking at all the downloads from them for all the drivers for your model of computer. Good Luck
Oct 01, 2007 | Toshiba Satellite M55-S3512 Notebook
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
