Toys Logo
Anonymous Posted on Feb 28, 2013
My daughter says there is a toy that is a ball that bounces on the water. Is she right?
Anonymous
Level 1:
New Friend:
  • Contributor 68 Answers
  • Posted on Feb 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
68
Questions
53
Helped
30048
Points
96
Yes she is - the Waboba surf is a great toy. It's brilliant fun in the pool and in the sea with all the family as it's a ball that actually bounces on the water.
Check out this info about it;
http://www.amazon.com/Waboba-Surf-The-Ball-Bounces-Water/dp/B004RGU0SK/ref=pd_sim_sg_6
Aside from what they are made from, how are soft gel medicine balls different from other medicine balls?
Soft gel filled medicine balls neither float nor bounce. This makes them the perfect tool to use while working out on any type of surface where you wouldn't want the ball bouncing back (such as on a trampoline).
9helpful
7answers
Wrong ball stuck in trunk of playskool ball popper
Search results brought me here in hope of finding location of all of the screws to take the toy apart. All but 4 of the screws are visible when then toy is fully assembled. There are 2 screws behind the ears (pull them away from the head, as they simply snap in place) that require a long shank phillips screwdriver to reach, and the other 2 hidden screws are behind a removable rear base adjacent to the battery compartment That one also snaps into place. Once all of the screws have been removed you can easily separate the front half from the rear half. In my case, there was a bread tie stuck in the fan. No amount of fishing would have removed it. Cheers!
2helpful
I need a replacement 27MHz remote control for a Playskool Tonka Bounce Back Racer model #09995. This model has been discontinued. Would another 27MHz remote, with forward & reverse control features...
Yes! The FastLane brand works. I thought my bounce back was a loss because the remote doesn't work until my older daughter played with her remote control car in the same room. The Tonka Bounce Back responded very well to the FastLane remote. And fortunately, FastLane is pretty inexpensive. Good Luck!
I lost my bop it bounce ball. How can I replace it?
Contact me and I will see what I can do to help: [email protected]
Jul 01, 2011 • Toys
1helpful
Does Hasbro games make replacement balls for the Bop It Bounce?
Yes they do. Just go to Hasbro.com and follow the links.
5helpful
My sons received the "Color
I have the same kit. Add the powder mixture to the desired ball mold. Let it sit upright in a cup of water for 5-10 minutes (and make sure the top gets wet as well).
Take the ball mold out of the water and let sit for another 5-10 minutes. Pop open the mold, and you should have a new bouncy ball!
Just some advice: make sure when you re-use the molds that none of the crystals get stuck in the tiny holes. Push out any remaining crystals with a pin.
Jan 02, 2011 • Toys
14helpful
Horizon Group Power Balls Super Balls made by me! has no instructions, can you help?
From the box:
Cover work area with scrap paper.
- Decide which shape mold and colors you are going to use to make your power balls.
- Next snap together the two parts of the plastic ball mold
- Open the color crystals package that you would like to use first and pour the desired amount into the funnel on the top of the ball mold. Do not fill the funnel part of the mold all the way to the top or your ball will not bounce very well when you remove it from the mold.
- Holding the funnel part of the mold, carefully place the filled mold in a cup. While holding the mold, fill the cup with water right up to the bottom portion of the funnel. Let the mold sit in the water for five to ten minutes.
- Remove the mold from the water and wait ten minutes before opening it.
- Carefully open the mold and remove the ball. When you remove the ball from the mold it may feel a little sticky. Let it dry until it is no longer sticky before you start playing with it.
- Find a clean, flat surface to bounce the power balls on. When you are done playing, store each ball in resealable bags until you are ready to use them again.
We need instructions on how to make a bouncy ball
try using elastics to make a ball, and it bounces.
Aug 20, 2009 • Toys
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
