Question about Acer Computers & Internet
Flashing Red, Green White & Blue
I have an Acer LC1715 lcd Monitor which on standby keeps flashing between red, green, white and blue colours accross the whole of the sceen. You cannot even power it off by the power switch you have to take out the power cord to stop it.
Any ideas to get round the problem.
  • jambala Mar 23, 2009
    Same for me. I have 3 out of 17 acer monitors doing this now (I work in a school; we have a computer suite). What's going on?
Hp w2408h monitor flashing red green black blue white
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
The monitor will not show a picture the led is flashing green
* If the issue is visible in the monitor STFC (Self-Test Feature Check), the monitor is defective. * If not, the issue is with either the video card driver or the video card.
* Turn off both your PC and monitor * Disconnect the monitor from the PC (either the white DVI or the blue VGA. They should never be connected at the same time to one PC) * Turn the monitor on * The floating Dell red/green/blue/white dialog box should appear on a black background * Check for the issue
Mar 02, 2011 | Dell E173FP 17" LCD Monitor
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Red, Blue, Green white flashing screen
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 04, 2017 | Acer AL2016W 20" LCD Monitor
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Screen flashing differnet colours
My Benq lcd monitor does the same thing.
Sep 17, 2007 | Videoseven R17PS 17" LCD Monitor
Computers & Internet Logo
1,296 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
