Question about Whirlpool GS6NBEXR Side by Side Refrigerator
After using the water dispenser on my side by side ED20DF the water keeps on dripping? I've turned the water off for now, but I need to know how to fix it. Help??? Thanks
  • rafaelhdez62 May 04, 2009
    I don
    Thanks,
    Rafael.
  • 3 Answers
Could be couple of thing, but I think that first you need to check the connector. You open your refrigerator from both sides and then pull out the grille (don't worry it won't break) then if you see at your left there's a connector that put together a 5/16 water tube with a 1/4 water tube, try to fit both water tubes in the connector, maybe one of those is loose and that's the why of the dripping.
The other thing may be is with the mechanical-electrical interface, when you press the paddle, is you see the activation under the dispenser, it touches with a limit switch, maybe the limit switch is stuck with something when you activate or it is not working properly.
Also if you have a multimeter check the valve to see if it's not a problem with the signal that is coming to the valve, I mean if the problem is that even without press the paddle the dispenser start to dispense water.
Posted on Feb 20, 2009
Slow drip from refrigerator water dispenser
Sounds like a defective water control valve W10408180
Change that out and I believe you will be fine. If you have questions please let me know, Thanks Sea Breeze
May 03, 2012 | Whirlpool Refrigerators
Hello, I've been using the "Whirlpool 25.1 cu.
Maybe trash has made its way to valve and it is partially stuck open. Or maybe all air is not out of line. Run water through dispenser until it stops splurting air and there is a steady stream of water.
Sep 23, 2017 | Whirlpool Refrigerators
Water dispenser drip
Use a cup instead of a paper towel. Empty as needed.
Jul 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
New fridge keeps dripping water from the
Behind the panel of the dispenser there is an adjustment screw to adjust the microw switch If this does not fix it then the valve needs replacing Thatis usaly located in the bottom of the freg
Jul 12, 2009 | Refrigerators
How do I get the water dispenser on the outside of the door to quit dripping water
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
Jun 30, 2009 | Whirlpool ED5FTGX Side by Side...
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Jan 17, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water dripps
I realize this is an old answer, but I'm experiencing the same problem and found what I hope is a much simpler fix:
https://youtu.be/hAEdjhaZoaQ
This is a Youtube video which explains how air trapped in the water line can cause a drip from the dispenser. Apparently, allowing a gallon of water to flow continuously through the dispenser should...uh...dispense with the problem!
Hope this helps you, and me!
Sep 21, 2008 | Samsung RS2534 Side by Side Refrigerator
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
