Question about Ricoh Aficio 1022 All-In-One Laser Printer
Scanner Setup The office that I am currently working at has there office printer set up incorrectly. How do it up to send scannes to a location on the server or a PC?
You need a software called "Scanrouter V2 lite", which is actually no longer available on the Ricoh download page for some reason. However it is quite difficult to configure, if you have not used it before. You will probably need to contact a Ricoh service department.
Posted on Feb 19, 2009
My scanner won't copy, all I get are black lines
Something could be electrical/mechanical mistimed now in a mechanical way dirty microswitches that have not give a break on the right moment to stop the scanner and has damaged something what has to made the loud noise .
Keep in mind your safety by working on high voltages and also mechanical recovery.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%201815dn%20Service%20Manual.pdf
Aug 11, 2017 | Dell 1815dn All-In-One Laser Printer
I have a esp office 6100 series all in one printer, it is connected to a fully functioning phone line - I have checked everything is working. Each time I try to send a fax I dial the number it dials 3 or...
most likely the fax is incorrectly set up as an extension in a multi-line system rather than a single "telephone". probably the fax injects digits such as a leading zero. the setup needs to be corrected.
May 27, 2011 | Office Equipment & Supplies
Scanner will not scan
Problems you may have while using the scanner often involve the operation of your software and computer. Operation problems usually occur because of:
Incorrect setup of the interface
Incorrect setup of your computer or software
Incorrect operation of your software
See your Start Here poster to confirm that you have set up the scanner in the correct way. Also, see the documentation that came with your computer and software for possible solutions
IF The scanner does not scan.
Try one or more of these solutions:
Wait until the Start button light stays green (ready for scanning).
Your system may not work properly if you use a USB cable other than the one supplied by EPSON. Use the USB cable that came with your scanner.
The scanner may not work properly when connected to the computer through more than one hub. In this case, connect the scanner directly to the computer's USB port, or through one hub.
Pressing the button does not start scanning
For Windows XP users:
Click the Events tab in your scanner's Properties dialog box and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
Oct 20, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Our office has a canon printe/fax/scanne MF3200 it was moved and when reconnected it stop working, I can not get the setting correct to get it to work, HELP
first check the cables is correctly installed, turn off the computer that is connected to the printer, and then
1. Turn on the printer
2. Turn on the computer
Aug 11, 2010 | Canon Office Equipment & Supplies
How do i scan a document on the Kodak 5300 AOI using Microsoft Word XP. Where do I locate the menu drop down to retrieve the scannned document from the scanner?
I think you need to install the microsoft office document imaging to be able to scan from word, this is what you do assuming that you have windows xp
Windows XP
  1. Exit all programs. Tip You may want to print this topic before you exit all programs.
  2. Click Start, and then click Control Panel.
  3. In Control Panel, click Add or Remove Programs , and then click Remove a program.
  4. In the Currently installed programs list, click the name of the Microsoft Office edition that you installed or click Microsoft Office Word 2002 (depending on whether you installed Word as part of Office or as an individual program), and then click Change.The Configuration Wizard opens.
  5. Click Add or Remove Features, and then click Continue.
  6. Under Installation Options, click the plus sign (+) next to Office Tools.
  7. Click the arrow next to Microsoft Office Document Imaging, click Run all from my Computer, and then click Continue.
once you have installed this in the insert menu, there should be an option to acquire image from your scanner, assuming that your scanner is properly installed and working.
alternatively you should be able to scan a document and send it to an application (word xp), page 70 of your printer manual will show you how, your manual canbe found here
hope this helps!
Apr 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
How to install a scanner setup and installation on my PC am using IR3300 xerox mechine kindly educate me.
Install scangear from cd or download it from canon download site, run installation, under scangear properties use "discover" button, set copier to online, open eg word2003, insert-picture from scanner or camera, choose scangear and custom insert.
That is short description, you can also download scann gear manual over canon download site.
Mar 02, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I am having problems scanning from my mfc=420cn. I don't know how to scann to file on windows vista/ or microsoft word. It only lets scann to images
Try setting up the scanner in the scanners and camera control panel.... more than likely you are just hitting the scan button on the printer and it is using the defaults on the printer's installed software and is automatically sending it to your images folder. Maybe some clarification on exactly what you want to do?
If you have office, open microsoft document imaging and acquire the file that way ( acquire scan, and then cut and paste into word)
Mar 08, 2009 | Brother MFC 420CN All-In-One InkJet...
How to scann photographic film fith epson scanner
Hi, I'm sorry to saythat this unit (DX4400) doesnt have the facility for film/negative scans
Dec 12, 2008 | Epson Stylus Multifunction Inkjet Printer/...
How to hook up?
This scanner may have a parallel and a USB port. Use the USB port, if it exists. If not, connect the scanner to the parallel port, then connect the printer to the pass-through port on the scanner. This can be problematic, requiring changes to the BIOS and driver difficulties. A USB scanner is a better solution, and they are cheap nowadays.
May 21, 2007 | Acer ScanPrisa 640P Flatbed Scanner
Ricoh Aficio 1022 All-In-One Laser Printer Logo
536 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
