Question about Gateway MT6840 Notebook
When i turn on my notebook it goes to gateway screen. then ate the bottom left it says f2 to bios menu. well any way, on the boot menu it say's media test failure and exiting pxe-mof. under that it says operating system not found. it will read os disk and it will not restore.i have a gateway mt 6840 what do you think my problem is?
  • sandman28625 Feb 22, 2009
    I got a new hd drive and that took care of the problem. Thanks
    President:
  • 1,223 Answers
Ur Hard disk is giving u problem either it is failed or going to failed jus buy a new hard disk whichever suits ur needs i mean , hitachi's are the best i think reliable and fast go and solve
Posted on Feb 19, 2009
Gateway sx series sx2110g-uw318 boot menu
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
Jan 26, 2014 | Gateway SX2110G-UW318 Small Form Factor...
Emachines Em250 has a blinking cursor after bios menu
May be a bad HDD. Can you access the recovery software at boot? Remove ALL media, DVD, CD, USB. Shut down, unplug, remove battery, plug in, with one habd push the on/off button, with the other press the Alt and F10 keys repeatedly. Here's the procedure: http://support.gateway.com/emachines/desktop/2009/gateway/dx/dx4300/DX4710faq6.shtml
Jan 17, 2013 | eMachines eM250-1915 Netbook
How do I get my Gateway laptop to boot?
F12 BOOT DIVICE MENU WEN LAPTOP IT TURING ON
Jan 11, 2013 | Gateway Computers & Internet
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Gateway CX2724 PC Notebook Problem
operating system of your pc is damaged so reinstall the os again or recover from the recovery CD
Jun 17, 2008 | Gateway CX2724 Notebook
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Gateway MT6840 Notebook Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
