Question about Sharp MX-2700N Color Copier
MX2700N printer keeps giving A4 paper error.
We have a Sharpe MX2700N machine that is asking for A4 paper to be loaded when we are trying to pring a normal letter size document. Have tried the same print job on a Sharpe AR-455N and do not get the load A4 paper problem. Works just fine. Is there something in the setup on the MX2700N that can be changed to resolve this issue?
  • pion46 May 11, 2010
    check in the key operator settings and see if the A4/LTR auto switch is enabled. That's the most common cause
    New Friend:
  • 91 Answers
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Posted on Mar 10, 2009
We have a secondhand Sharpe MX2700N and would like to set the 'colour print option' as Password protected (to ensure this colour print option is not selected in error) - any ideas as to how to set this? Black/White option OK as is.
Many thanks.
Posted on Mar 11, 2011
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
How to fix PC Load A4 printer problem
A4 refers to a paper size, so its asking for that size of paper to be loaded.
Mar 15, 2015 | HP LaserJet 4 plus Printer
Remove paper from sheet feed when no paper loaded
It is possible that the genuine replacement HP sensor is defective.
Jan 09, 2014 | HP DESIGNJET T770 Printer
Give me a paper size error
Try set manual,by pass tray.
Apr 20, 2013 | Konica Minolta Di1610 Copier
I defined the paper size A4 but Canon gives an error and ask me to use the current size. If I push yes it prints again
go to printers and faxes right click an d select printing preferences on 4350d and select paper as A4 . Press apply & ok. Now try printing on A4
Apr 10, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Hello, I have (had) a paper jam on a Sharp MX2700N. I have removed all copies but am now advised to call for service Code H5-01. Any ideas?
after call for service, the machine will indicate an error code like H4, F2,etc. if you can give me the code i will know what to do
Feb 03, 2011 | Sharp MX-2700N Color Copier
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
A4 paper giving error
When you print, under "Paper" be sure that the paper source is set to "Auto Select" in the options.
Apr 08, 2009 | HP LaserJet 1005w Printer
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
Sharp MX-2700N Color Copier Logo
1,043 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
