Question about Creative Labs ZEN Vision:M Digital Media Player
My creative zen vision w is not seen by pc says usb malfuntion wont regonise
I had the same problem. not the USB or PC, but the player. I think you might need to reboot your player. Power on, holding the switch in the on position, and get a safety pin/paper clip and hit the reset button, beside the power docking input. It will give you a series of options, of which I found the Reboot to work.
Posted on Feb 25, 2009
Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Aug 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
It won't transfer my zen vision M songs from my computer
I've been able to solve the problem I had with transferring files to my Zen Vision M.
I uninstalled all components of Media Source 5 and Zen Vision M Series Explorer on my PC. I then reinstalled them again. I also rolled back to Windows Media 10 (as I recently upgraded to v 11) and unchecked Sync with Zen Vision M in tools/options/devices on WM player. I then run the Clean up in recovery mode on the Zen. When the PC restarts after the installation of the software it will ask for you to connect the player. The PC should now successfully transfer files to the player.
Hope it works for you too.
Apr 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Firmware problem
See the solution for PC not recognizing your player. You should downgrade to WMP10 by uninstalling WMP11 and WMP11 runtime. Uninstall portable device drivers from System menu and restart the computer. Replug the USB and the player should now be recognized.
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision m wont charge
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Jan 08, 2008 | Creative Labs ZEN Vision:M Digital Media...
Downloading music from windows media
Your music files are corrupt, or they are a file extension that the Zen is not compatible with. I recommend you download a few MP3 songs and try to download those, as a test.
Oct 23, 2007 | Creative Labs ZEN Vision:M Digital Media...
Vision m 39gb dpvhd0003
Have you only been attempting using a USB port to charge it? I just fixed my problem. I have a wall charger from the Creative Zen Touch that worked perfect on it when the USB didn't do a thing. Usually I'm able to charge it with my RAZR phone charger in the wall but that didn't work and neither did my computer charger via USB but I tried the old wall charger and it seemed to do the trick. If you don't have one, they have them on amazon, here is the link: http://www.amazon.com/Creative-Zen-Vision-Travel-Charger/dp/B000GWLL0K/ref=pd_bbs_sr_2/105-1441709-3982806?ie=UTF8&s=electronics&qid=1185509740&sr=8-2 or for the old one that I have: http://www.amazon.com/Travel-Charger-Creative-Touch-Vision/dp/B000H19KC6/ref=sr_1_3/105-1441709-3982806?ie=UTF8&s=automotive&qid=1185509930&sr=8-3 Hope this helps!
May 15, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
