Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Ceiling Fan Light Switch stopped working
My Hampton Bay Ceiling Fan switch light stopped working yestereday. The fan has five blades and five lights. The existing switch has three wires (red, blue, and black with a female/male connection) I've been to both Lowes and Home Depot and although both do have generic products that are supposed to fit most fans, neither has a product that works for my fan. Where can I find this replacement part?
I was able to resolve the problem. It turned out that the light fixture part that I had received from the associate at The Home Depot was the wrong one. I needed a 3 speed not a 2 speed replacement part. However, I ended up not even needing that. Once I took the fan apart and watched it malfunction, I could see that the clear part holding the fixture rope on my older fan had another circular piece in the center that had become loose but had not fallen out. I simply used a very small piece of blue paint tape to seal back in place. Since the area doesn't get hot, I found this to be a suitable solution. Thanks for your help.
Posted on Feb 20, 2009
I have a Hampton Bay ceiling fan Model BC552. light works, but fan does not. there is vibration (hum) when fan motor is switched on, but fan blades do not move. Blades rotate freely.
Start up capacitor is likely bad. That's the rectangle thing in the bonnet with two wires. If you replace it, replace the on/off switch at three same time.
Oct 10, 2017 | Hampton Bay Dryers
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
How do I replace the light switch in a hampton bay indoor ceiling fan with light? four blade fan with a single incandesent light bulb hanging below the fan blades. The switch is a pull chain that is not...
Hi ,,, replacement switches for ceiling fan lights can be found at most appliance or building supply stores. Try Home Depot, Ace, Lowes. Make sure that you get the correct switch. With a single lamp you only need an on/off switch.
May 02, 2010 | Hampton Bay 24002 Ceiling Fan
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Lights don't work
Don't know if I can solve it, but it is a Home Depot private lable. Try googling it and see if you can get some info. I suspect that you either hooked it up wrong, or it has damaged contacts.
Mar 28, 2009 | Hampton Bay 24002 Ceiling Fan
Wiring Hampton Bay Fan
The blue wire is for the light.This should connect to the other switch instead of being combined with the fan switch.
Sep 09, 2007 | Westwind Classic Hugger Polished Brass 52"...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
236 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
