Question about Sony KP-61HS30 TV
TVs remote sensor not working
I bought a brand new remote and it still won't work. I believe the problem is with the TVs remote sensor. It is not picking up signal from remote.Any suggestions on how to fix
I'm having the same issue. I think we have to get it repaired.
Posted on Sep 07, 2009
Bought a replacement remote RCM 8080 for easy touch TV but it won't work
If the remote control you've bought is its original replacement [number]; it should work with the TV without any problem. If not; the infrared sensor inside the TV should be checked and replaced.
If it is a universal remote control; you have to set it up with its set-up code; said to your TV brand.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 14, 2014 | Televison & Video
Bought new 650 remote to replace aging 520 which still works. New remote works but ca't get volume to work at same time as changing channels - can only do either or. Q- can I sync the 520 with the new
If it is a universal remote control, set-it up with an other code stated for your device brand. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Nov 10, 2014 | Logitech Harmony 650 Remote Control
Phillips 42 inch #242254901817 will not respond at
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
You here reports that even the new remote too does nor responds. Which remote did you bought? An original one or a universal remote? If it is an original one, and even your set do not respond it, the infra-red sensor inside the TV is faulty. Replace it. Contact any service technician. If it is a universal remote control; you have to set it up with the set-up codes said to Philips brand TV [The setup code list will accompany with package of each universal remote control], to work with it.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Oct 19, 2014 | Televison & Video
Remote on apex tv will not work bought a new remote and will not program
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Aug 05, 2014 | Apex Digital Televison & Video
Remote does not work
Infrared sensor inside the TV is damaged. Replace it.
May 17, 2013 | Televison & Video
I bought a Sylvania TV, model 6420FF at a second hand store with no remote. I bought a universal remote and it still won't recognize I have the xbox or Wii on. What to do?
Setup codes to check with Sylvania brand TVs are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
For more codes to different other brands of remote controls, and setup proceedings, check this link.
Feb 05, 2013 | Televison & Video
Can a tv lose the ability to read codes from a universal remote cause i tried three different un. remotes and my tv doesent react to them.. thnx
If the infrared sensor inside the TV is faulty, TV won't respond to any remote controls. You can make it sure by looking into TVs standby light. If standby light on TVs front panel blinks once, when you press a key in the remtote control, make sure that the sensor inside is working properly, and the code you are trying to enter is non once for your Brand TV, If there is no blinks as such stated above, make sure that the infrared sensor inside your TV is faulty. If you want more details about codes, setup proceedings, repairing a remote & checking it, just visit this site. Th site name is "Electro-help".. Just search for it by type in 'electronicshelponline' in your browsers' search page. It is a blogspot site, in English language.
Jun 22, 2012 | RCA Televison & Video
I bought a sylnania plasma tv just couple years ago i lost the remote and have bought many universal remotes and none have worked i have seen people say that it could be the sensor but its a new tv an
Infrared sensors inside TVs can be damaged at any time. They are cheap to buy, and easy to install.
Check this site for more details. "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
Jun 17, 2012 | Sylvania Televison & Video
Remote control issue
It would be best, to simply buy a new remote control. I own a One-for-All universal remote control (model URC-4220), and it works with all brands of TVs, including Insignia TVs. I bought it at Walmart, and it cost less than $10.
Jul 07, 2008 | Insignia IS-LCDTV32 32 in. Television
Sony KP-61HS30 TV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
