Question about Sunbeam Refrigerators
Hums loud My refrigerator hums very loud it has a dial inside the refrigerator itself called the multi flow system. What can I do.
5 Suggested Answers
Lee123
  • 42 Answers
SOURCE: kenmore side byside refrigerator
Maybe you have some sort of a blockage in the pipes or the water cooler has an electronic fault and mabye needs replacing. Ask an expert such as a plumber. I'm glad i could help. Good luck!
Posted on Sep 11, 2007
Sea Breeze
  • 4655 Answers
SOURCE: humming sound and not cooling
Make and model number? May be not defrosting but will be able to help you better with the most important information. Sea Breeze
Posted on Apr 24, 2009
  • 161 Answers
SOURCE: lg refrigerator LFC22740ST loud humming noise no
You have a bad fan motor ... replace motor.
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: condensation on inside of refrigerator and frozen
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Replaced a leaking condenser coil and compressor on the model 795.72063.112 .however the unit is not cooling nor freezing .
I suspect that the humming noise is from a compressor motor that has liquid on top of the pistons and is in hydraulic lock
Why -- possibly adding liquid refrigerant and not gas
adding gas into the wrong side of the compressor
blocked high pressure line from the repair
time to call a technician in to help diagnose the problem
Nov 07, 2016 | Frost Refrigerators
Loud hum intermittent throughout the day and night
The hum that you hear is due to the compressor vibrating and cause by a nut not so tight. Check it's back- a bumping motion into metal case will also cause that hum. If none of it cause the humming, it is the compressor itself causing it. But there nothing you can do because it is sealed.
Thanks for asking.
Jun 25, 2011 | Electrolux EI26SS55GS Stainless Steel ...
I just bought a new frigidaire refrigerator. I plugged it in and it began to emit a large loud humming noise. It almost sounds like something is vibrating inside. Is this normal for a branc new fridge?...
It depends....it may be loud for a hour or so, but should quiet down as it cools...
There is an explanation for this, but it is very long and would involve intricate details about refrigeration systems...
If it does not quiet down after a 1/2 day then call the place where you got it and return it...
heatman101
May 10, 2011 | Frigidaire Refrigerators
I have a split system trane I16i 5 ton making a loud humming noise when it is in the first stage once it kicks into 2 stage it sounds ok
Trane has issues with loudness of their 2 stage system. Not saying its normal just saying its common. If you notice cooling ok in both stages then it can be narrowed down to refrigeration flow is noisy or a solenoid valve is loud.
Aug 20, 2010 | Heating & Cooling
MY GE Refrigerator-Freezer , model TCX20 motor is humming!!!
There may be a build up of ice in the freezer compartment and ice touching the fanblade. The unit needs to be defrosted.
Nov 06, 2009 | Samsung RS2630WW Side by Side Refrigerator
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Feb 09, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Kenmore side byside refrigerator
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Sunbeam Refrigerators Experts
paul
paul
ray gallant
Jorge Rendon
Jorge Rendon
Are you a Sunbeam Refrigerator Expert? Answer questions, earn points and help others
