Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
I heard a pop sound and now the only thing that happens is the power light blinks 10 times. I woul love to fix this my self if I knew what part went bad.
  • 2 more comments
  • Anonymous Feb 28, 2009
    Screen just went blank whilst watching, now the power light is blinking red 10 times
  • aaron770 Mar 02, 2009
    watching tv, heard loud pop, light blinks but nothing else will happen
  • Anonymous Apr 08, 2009
  • Anonymous Apr 16, 2009
    i just bought mine, and this!
  • 21 Answers
Flashes 10x - power supply board shorted.
Posted on Mar 11, 2009
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
I have a Samsung TXF2899 28" TV that is not turning on. When I press the power button on, I hear the power-on sound, it's red power indicator light blinks 10 times as if running a test but then...
It's running through a self diagnosis when the light blinks. The 10 blinks just happens to be how long it take to find a problem. Would have to be plugged into Variac and started at about 90 volts in order to keep it from shutting down. The life of a Television is averaged at 10 years, however most last longer and it could be something very simple to fix or something major. Thing is get an estimate from a reputable co before having it fixed and consider the cost to repair, age of the TV vs the price and warranty of a new one.
May 22, 2011 | Samsung TXF2899 28" TV
Sher3sc@aolI have a Mitsubishi hd 1080 series and the power button goes off as soon as you turn it on. How can I fix this?
The set has a self check feature: when green light (power) goes out on the front of the set press and hold both the menu and input buttons at same time for at least five seconds and release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
If the set was unplugged you will have to try to turn it on and then do the check.
2,2 is short protection and usually means (98%) convergence problem.
1,2 is no error detected etc.
Let me know what you find and I will help.
May 12, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Sep 13, 2010 | Televison & Video
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic TH 42PX50U Red power light flashes 6 times
Most of the time when this happens it is the ysus board, that noise you heard was a capacitor popping. Another board runs about $175 and thats if you do it your self. A shop will most likely charge around 500-600, hope this helps, you could also try contacting panasonic and trying to get past the tech and onto casemanagement where you might get somewhere with an out of warranty fix.
Feb 06, 2009 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Turns on, blinks 8 times, turns off
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Feb 11, 2008 | Sony KP-53V90 53" Rear Projection...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
259 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
