Question about Epson Office Equipment & Supplies
When using the Epson RX2880 ink jet printer which option shoukd u choose on the printer set up page: let the computer handle the printing or let the printer software control the printing
SOURCE: no ink on pages
Try cleaning the small tube that is located under the sponges. When it becomes clogged no ink will go to paper. Move ink cartridge cradle to the left,now pull out wiper sponges,clean them and flush out tube re-install sponges and do test page.
Posted on Oct 06, 2007
  • 4 Answers
SOURCE: EPSON CX5500 SUCKS ink....
Epson printers will clean the head if the printer is not used for a long period say a week. The only option is to switch on the computer and printer and give a noozle test every 2 -3 days. This will stop the printer from doing a head cleaning which uses the following amount of Ink
Black 1/8
colour 1/16.
Thus if the head cleaning is done 4 times your black is half empty.
thus as the saying goes either you switch on the printer every day or loose the printer
I also had the same problem and now this is what I am doing, and now the cartridge is giving a good amount of prints that too image quality
regards
N.kumar
Posted on Sep 30, 2008
admin734
  • 268 Answers
SOURCE: lost software having trouble installing
You can download the drivers for that printer here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14403&prodoid=21643927&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=14&y=14
The driver is what enables your computer and printer to communicate....that should get you printing again!
Posted on Oct 05, 2008
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
  • 421 Answers
SOURCE: I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Posted on Jan 13, 2010
Why won't my printer print more than 1 Page at a time?
Please go to your printer preferences and select page setup choose default setting and customize other page setup then click apply and restart your PC. If not done then follow the instruction.
1. uninstall your present printer driver.
2. Restart your pc.
3. Install your printer driver again.
4. Restart your pc.
Hope it will solve it.
Thanks
Apr 07, 2016 | Epson Stylus Photo R3000 Inkjet Printer
I have just replaced my ink cartridges, but now it wont print anything even though it makes the right noises. it whirs and takes the time it would to print something, but the page appears blank.
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink. The printing device consists of a print head and cartridges with ink. When you change the cartridges that does not mean you change the print head, like in some other models. Now you can choose the "head cleaning" option from the printer settings a couple of time. If this does not help you have two options - to get the device to service center or buy a new one. The second option is the cheaper one I suppose. And remember for inkjet printers you must print at least 1 page per week to keep head from clogging with ink. Hope this helps Alex
Sep 11, 2011 | Epson STYLUS CX5900 Printer
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Epson CX6400 Wont Print after being left on for a week.
I agree with Epson. Epson printers are very very hard to unclog. You can spend around $25 for a cleaning kit and *maybe* get it to work, or get a whole new printer that is faster and better quality for less than $100.
You can http://www.inkjetrefill.com/epson_clean.htm
Oct 07, 2009 | Office Equipment & Supplies
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson CX4800 dried ink
You can use the "Clean Print Heads" function if your printer allows and provides such an option. You can find this option via the printer proprties (Start > Printers and Faxes, right click your printer and select Properties. The clean options will usually be on the Maintenance tab)
May 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
Apr 04, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus 1520
Two possible causes
1. printer software option are incorrect
Check: Print quality and set it to economy
Highspeed On
Choose Black ink
No halftoning
2. Change your default spool directory and other settings
Jan 16, 2008 | Epson Stylus 1520 InkJet Color Printer
99 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
