Question about Epson Stylus Photo R220 InkJet Printer
Tray wont go in, not accepting tray, keeps saying reload tray and press paper button on printer, and im getting ink blotches on the tray and the disk when it does print.
  • Anonymous May 02, 2009
    Printer kicks CD/DVD tray out - red light (middle one) comes on solid. Resetting CD/DVD tray does not fix.
Lightly sand paper the underside of the CD/DVD tray, it is probably just slipping.
Posted on Apr 08, 2009
Im trying to remove the paper tray, but it's giving me a hard time. The Quick Setup Guide says to just pull it out but mine isn't coming out. Is there a button that needs to be pressed in order for the...
did it ever get pulled out before because it could be that it was inserted wrong or if it wasn't pulled out it could be that the tray is stuck because of ink or dust build up
Jan 05, 2014 | Brother MFC-290C Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
It says load paper tray 1
Oct 05, 2010 | HP LaserJet 2840 Printer
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Wont accept paper
You need to take it to a Epson Express Centre to be looked at. Most likely your waste ink pads are full.
Mar 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Epson Stylus Photo R220 InkJet Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
