Question about Sony VAIO VGN-FS742/W Notebook
Virus attack (keyboard, touch pad, network, any button on laptop
--Internally built in hardware are not working, such as - keyboard, touch pad, audio, internet, macro button (extra buttons), finger print reader.
-- problem at start up itself (at welcome screen I could not type password or finger print authentication) ,I use usb key board to login.
--Restore is not working, showing no restore point.
--Usb keyboard and mouse are working, display is working
--every 5 sec it pops that battery not connected properly.
--I know its virus (since I tried a crack for some software And it eventually created all these problem)
--I got dual boot on my system Vista + Fedora 10, and problems are on Vista , there is no problem in using Fedora 10. But i got some very important software (related to my profession) on Vista (not available on Linux).
More details , about problem, or solution at
simaich8@aol.com
    Problem Solver:
  • 13 Answers
Try this: Download free program combofix and run. When finish you will see all bad files what he detected and fixed.
Posted on Feb 19, 2009
My keyboard and touch pad compaq presario cq40 not working i try to reinstall keyboard and touch pad but it still not working ,and then i remove to put new keyboard but it still not working at all..... so...
You tried to reinstall the keyboard and touchpad hardware parts? Have you had ANY damage? Spill? OS upgrade? If you replaced the hardware is the ribbon cables connect properly?
Apr 19, 2013 | Compaq Presario CQ40 Series Laptop Charger...
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
Laptop touchpad not working
Directly above the touch pad is a button (sometimes has a light around it red off, blue on). This button turns the touch pad off and on. Once you press the button, give the laptop a second or two to recognize the device and then try it. If this does not work look under device manager, to see if there is anything next to your mouse devices. If there is an explation point or anything you probably need to reload the drivers. If there is a red X, this will normally indicate the touch pad has been disconnected physically. If you are somewhat hardware savy, remove the keyboard and check/reconnect the touch pad.
Hope this helps.
p.s. no I did not give instructions on how to take apart the computer or remove the keyboard. If you do not know how to do this, I would not recomend that you do.
Apr 12, 2012 | HEWLETT-PACKARD 620 XT964UT Notebook PC
The built-in keyboard of My Acer-Aspire 4741Z Notebook, sudently stoped responding..built-in mouse (Touch-pad) is working..Pls advise me
Press poweroff button for some time, the laptop will go off. Then once again start the laptop by pressing the power button. This method is named as "Cold reboot".
If still issue, please post on this.
Thanks,
Amar
Sep 22, 2011 | Computers & Internet
I am typing off the laptop keyboard itself and as I am typing it jumps back into a previous sentence or previous paragraph
Most likely culprit:
Do you have the finger touch-pad turned on?
Chances are you're brushing up against that, high static will increase the likely hood.
I don't even have to touch mine.
If you have a button to turn it off - great! Turn it off while you're typing.
I've seen some that lack this feature. I'm not sure if it can be disabled in the task bar; or if you'd need to disable the device through the hardware/device manager.
Another option is to just make sure your hands/wrists are elevated -- They really should be anyway to avoid carpal tunnel.
Other possiblilities:
Hitting the: home, pg up, pg dn, and/or end keys -- Arrow keys as well, will do it.
Some sort of software malfunction. -Perhaps, glitch or compatability issue.
Virus/someone's accessing your computer - Usually they don't just play around with your sentences though. ;-)
Broken keyboard.
Hope this helps!
Alex
Mar 23, 2011 | Computers & Internet
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Acer Keyboard Will Not Work
try using an usb keyboard, if you can use the usb keyboard it's an hardware issue and you need to plug it to the motherboard yourself or just ask the manufacturer to do it for you.
If an usb keyboard doesn't work you have a software issue and in case it isn't a virus, all you have to do is a system restore.
Cheers
Jun 09, 2009 | Acer Aspire 6930-6455 Notebook PC
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
Sony VAIO VGN-FS742/W Notebook Logo
570 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
