Question about Canon Office Equipment & Supplies
Can't install printer
Downloaded the driver from the cd. Downloaded and installed ok. Can't get pass the connection stage, get message saying check connection. I went back to the next page and get a message driver not installed. I went to the hardware program and it shows printer installed with a question mark. I clicked on the printer and get a message this device is not configured correctly (code 1). I tried re-installing the driver but still having the same problem. I am trying to install this printer in an Averatec all-in-one with Windows XP Home Edition Sp3.
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the below given link by selecting the printer model.
http://software.canon-europe.com/index.asp
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Posted on Feb 19, 2009
Lost CD & Manuals For instructions To connect Printer To LAP TOP Need Info. How To Install Same Thanks
Click on the link below to download the software for installation.
Choose the operating system and download the DRIVERS. ( usually 32 bit is common PC Operating system for XP, VISTA or Win 7 )
Download Drivers
User Manual
First step is to run the wireless setup wizard from printer front panel
Press the Setup button on printer front panel - Press OK
Use the arrow keys and locate Network Connections - Press OK
Locate the Wireless Setup Wizard - Press OK
It will search for the network Name ( SSID )
Enter the network key if your network is password protected.
Press OK
It should give you message as printer connected to network.
Run the software driver file that you have downloaded and choose the Wireless option to continue with installation.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 07, 2010 | HP J4680 Office Jet All-In-One Printer
Usb error
To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Jul 23, 2010 | HP LaserJet P2015 Printer
I connected everything and ran the disk, but I keep getting a message that the printer can't be found. I have double checked all my connections, they're ok. Why can't my compurer find the printer?
unplug the printer, right click on the 4200series an click uninstall. Once uninstalled, reboot. Once the PC is on again plug in the printer. You should hear the ding that a devise was plugged in and the little bubble will pop up saying installing new device. It should find the driver and install, but if not have your printer CD ready to insert. If asked for the driver say "have disk" and open the CD rom to the driver directory or just tell it to search for the driver.
Dec 31, 2009 | Lexmark X4270 All-In-One InkJet Printer
Hi, i'm trying to set up and install my new brother HL-2140 laser printer using the installation Disk that i received with the printer. The problem is that the installation is interupted because it says...
uninstall the driver, disconnect printer, restart pc.
start CD installation *DON'T CONNECT THE PRINTER till it ask for it.
When it report error for missing file, go to browse then locate on CD install>eng>PCL>win2kxpvista>select BH2170W then click ok.
It should be working.
Nov 13, 2009 | Brother HL 2140 Laser Printer
Computer can't "see" scanner even though plugged into USB port
please check:
if other usb-devices work with your pc, so usb ports of your machine are ok.
try connecting the printer to another machine, using same procedure as u did with the old one
did you get any installation cd with it?
any newer drivers for your win-system available?( inet, manufacturers homepage)
if your system and the printer passed the hardware check, install newer drivers and try again.
wish u luck
Jun 18, 2009 | Ambir Technology DocketPort 485
My downloaded cd from lexmark site didn't work!!!
Hasn't passed windows logo testing to ensure compatibility just means that Microsoft hasn't tested those particular drivers in house to make absolutely 100% sure the drivers are stable.so download the drivers from anyother site try this site click it directly http://www.printcountry.com/drivers/LEXMARK_P4350_DRIVER_DOWNLOAD.htm
Jan 28, 2009 | Lexmark P4350 All-In-One InkJet Printer
Software for CX3200
The links on the page expire every 20 mins. here is what you need to do
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the ALL IN ONE heading select and then your scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
4. Complete the same steps for the printer model.
Scanner install
Make sure your USB is disconnected
1) Double Click on the Epson1****.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
Automated USB Driver Install
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) At the PRINTER UTILITY SETUP screen, click on OK.
7) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
8) The computer will install the new hardware.
9) Click on OK when the driver installation is completed.
Aug 11, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printing CD on Espon R260
I have a new G5 Mac. I downloaded an updated driver from Epson and then clicked on Update Printer Information. I had failed earlier to click on this button after downloading the new driver.
Apr 18, 2008 | Epson Stylus Photo R260 InkJet Printer
Cannot re-install Lexmark X6170
I get the same message when I try to install downloaded driver, 'user cancelled' or 'cannot install'.
Can anyone out there help?
Jan 01, 2008 | Lexmark X6170 All-In-One InkJet Printer
Mp600 can't load drivers
Try deleting any previous drivers installed,unplug the printer USB from the computer. Restart the computer run the driver CD leave the printer unplugged then when the cd asks for the printer,power it on and connect it to the computer let it install automatically see if that helps good luck.
Nov 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
59 people viewed this question
old marine
old marine
