Question about Whirlpool Dryers
Whirlpool gas dryer model lgr3634jw0 won't start. Dryer is used about once/week during winter months. Was operating properly when last used last week. Think an electrical component has failed but not certain. Any suggestions would be appreciated.
After several days trying to locate the problem, I decided to junk the machine & buy a new product. The machine was 8 years old and I accidentally broke the igniter while trying to dissamble the various pieces of the machine. The igniter wasn't the problem nor was the problem ever definitely diagnosed. With this machiine's relative little usage & unresolved electrical failure, the machine reflected its poor quality of manufacture.
Posted on Feb 20, 2009
Whirlpool Cabrio dryer won't start - the sensing light stays on
An EXTREMELY helpful technical guide is folded inside the console housing.
WARNING: It is for appliance techs, DO NOT do the voltage/resistance checks if you are not well-versed in troubleshooting appliances! BUT, it does include putting the dryer in diagnostics mode and checking the sensors.
Post back any error codes you may get.
Oct 22, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
The dryer is under a year old and was setting in the garage for 6 months not being used. Now its hooked up and operates but does not heat up. Help?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 14, 2010 | Whirlpool Dryers
What kind of maintenance should i do to my 1989 cbr 600 f to keep it in tip top running condition
  • Change gearbox oil every 3000 miles. Change oil filter every 6000 miles. Use 10w40 motor oil. NEVER use synthetic lubricants as they can mess up the clutch.
  • Oil the chain every two weeks. Lube the control cables every oil filter change.
  • Keep the gas tank full in the cold months. This lessens internal tank rusting due to condensation in the tank. Drain the carbs when the bike will sit over the winter unless you plan on starting the bike every two weeks and letting it run for 15 minutes each time.
  • Be sure the gas valve is turned off when the bike is not in use.
  • Get a 2 amp trickle charger and charge the battery once a week for 4 hours in the winter. Be sure to keep enough water in the battery to cover the top of the plates in each cell. Know that batteries only last two years or so.
  • Check the chain tension once a month during the summer riding season.
  • Please rate my answer. Thanks.
Sep 11, 2010 | 1989 Honda CBR 600 F Hurricane
Intermittent high-pitched noise during drying cycle
It is probably the drum bearing going bad and yes it is okay to use but will probably sart clunking when it wheres out all the way.
Mar 11, 2010 | Dryers
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Gas dryer not drying properly
you would want to check the force of the air coming out of your vent at the outside.if this is not great.check to make sure your duct is not kinked or your lint screen is clean.if you have already done this.then you have an internal block in your dryer duct.you will need to call in your local tech.
Jun 03, 2007 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
