Question about Garden
20 amp fuse blowing
Fuse blows intermitenly then the mowers fine.usually happens after half an hours use,yesterday blow 6 fuses one after another.the fuse was blowing with the machine switched off,after a ten minute rest the mower worked fine again.the mower is 2 years old and as had little use.
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
  • 22 Answers
SOURCE: 13.5 OHV B&S won't stay running, blows gas out carb.
Sounds like you have a blown valve. I'm assuming this is a 4 stroke motor, if it was 2 stroke then it would be the reed valves. But either way it's the valves.... unfortunately that will require a mechanic :(
Posted on Jul 19, 2009
SOURCE: briggs and stratton engine blowing fuses
starter overdrawing perhaps
Posted on Aug 02, 2009
mickey813
  • 472 Answers
SOURCE: My mower keeps blowing the 20 amp fuse that is on
ck the wires going to yhe head lites theay could be frad and shorting out
Posted on Oct 01, 2009
SOURCE: I have a problem with a Black and Decker electric
Hello blumph,
I can think of only one or two things that are causing your problems. It could either be approx. a $14.00 switch in the handle that has shorted out, or 2 bad brushes $1.75/ea.on the armature (motor). Both are fairly simple fixes with just a screwdriver and maybe pliers. You might also check and see if the power cord has been chafed or damaged and is shorting out.
See below for parts:
http://www.ereplacementparts.com/black-and-decker-mm575-electric-lawnhogtrade-mulching-mower-parts-c-4167_9514_9550.html
yurcarguyken@yahoo.com
Posted on Oct 07, 2009
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
1992 gmc pickup keeps blowing heater fuses I replaced the blow motor and it keeps blowing
Have you replaced the blower resistor . some times they can cause the fuse to blow . You may need a muiltmeter to test the current draw on the blower motor circuit. the draw should be less then half of the rated fuse .( 20 amp fues draw is less then 10 amps) You did not say but does the blower work on high only or the lower speeds with out blowing the fuse ? if it does work on low or high with out blowing the fuse i would replace the blower resistor
Mar 06, 2011 | GMC Sierra 1500 Cars & Trucks
Starts and runs good but after an hour of cutting when you turn off.. then you want to cut again it will start just fine but when you engage the blades the fuse blows it has a 20 amp fuse is this the right...
I normally see 30 amp fuses to the deck...but it depends on which mower you have. If you place a larger fuse and it does take a 20 amp..you may burn something up. I would check the blades, spindle towers and clean all the stuff on top and inside the deck to look for something catching on the blades. www.nnyparts.com
May 27, 2010 | Garden
Cub Cadet zero turn:Engine starts and runs about 5 seconds before blowing 20 amp fuse.
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
Aug 24, 2009 | Mtd Gold 42" Zero-Turn Mower -
Fuel ECU fuse keeps blowing (30 amp)
Your fuel pump is internally binding and causing the fuse to blow. Change the pump (and filter while you're back there.)
Jun 14, 2009 | 1993 Jeep Wrangler
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
