Question about ASUS P5S800-VM Motherboard
My pc does not start
Keyboard error!!! how can i solve this?
Mother driver asus mother board model no: a8v-vmse misplace
Posted on Feb 20, 2009
  • 1,602 Answers
THE KB MAYNOT BE SUPPORTED BY THAT MANUFACTURE, FAILITY PLUG IN OR DEFECTIVE WIRE THAT RUN FROM THE KB OR THE DRIVERS ARE NOT CORRECT FOR THAT CERTAIN KB.
Posted on Feb 19, 2009
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
When using my laptop it behave like any body has press backspace key I wont stop this problem,again I am pushing backspace key with my other hand it functioning properly,if I remove hand from backspace...
Hi dipannvora,
This could happen when they keyboard setting is malfunctioning or there is a possible virus which is the reason behind this misbehavior.
I would suggest you start the PC in safe mode and then check if it works fine , if it does , then the problem could be with a virus , else you need to get your laptop's keyboard serviced and the problem would be solved.
Aug 01, 2011 | Computers & Internet
When I switch on my PC with on button.. pc is on fan is run and keyboard light is blink is one time but there is no display on my monitor... please help me what i do..
Hello!
1. Check the cable from PC to Monitor. Not solved? go to no...
2. Restart you computer enter to Set Up(Bios) enable onboard.(Applicable only to Not Shared Vram) Not solved? go to no...
3. If you have seperate VCard try to removed and clean, then start again.
Give me feed back what results you got..
Thanks!
Mar 16, 2011 | Intel Desktop Board D945GNT Motherboard...
New system. Cannot enter bios with F2 key, apparently keyboard is not working, but works well in another computer. I tried bios switches 1_2 default and 2_3. With 1_2 it goes directly to PXE_E61 error,...
hallo there, tried the DEL key? (instead of the F2, some Bios of them use older input for F2, DEL sends same key. )
Also, please count how many short, how many long beeps mopbo gives when booting.
Also: try to connect with PS2 keyboard. Possible no correct keyboard connection or even worse, when its a wireless keyboard need tyo pair keyboard with receiver first.
Also possible: is the keyboard not IBM compatible?
As said: try first to use default PS2 keyboard, theyre cheap and most of the times problem is directly solved.
If that does not solve your problem, count the beep codes and tell us please, could be some other problem, ( wrong memory, memory not placed correct, voltage problems etc etc etc)
the bios codes would help us to help you fasst.
Greetings
Ganimidis
Mar 13, 2011 | Intel DP45SG Motherboard
Keyboard error or no keyboard present, the
Have you tried to disable the PS2 keyboard and plugged in a USB keyboard..? You may have to go into the bios and switch on USB legacy support..
Nov 12, 2009 | ASUS P4B266 Motherboard
PC starts fine, but at the msi motherboard logo it
this is just a sugjestion,,i had the same problem and i cleared the bios with the jumper on the mopther board and it solved my problem..hope that helps
Nov 06, 2009 | MSI K9MM-V Motherboard
I m not geeting a proper sound driver for my pc
You can get the motherboard information by forcing a keyboard error. Before starting up your PC, remove the keyboard. On default system setups, this will prompt a keyboard error and display your mobo/BIOS information long enough for you to write it down.
You can search the internet for your owner's manual with this.
Hope this helps.
Jun 27, 2009 | Biostar M7VKQ Motherboard
Clarification about my foxconn bios checksum error
try to change cmos battery...
or
flash BIOS
download bios from bellow link
and pls refer the manual.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000004
thnaks
if ur problem solve so pls rate me..
bye
Mar 05, 2009 | Foxconn 661FX4MR-ES Motherboard
System cannot start at all...
it seen to be like u r window is currepted man.. re installing window may solve ur problem.. best regards mail-sigma_shiva1@yahoo.co.in
Oct 09, 2007 | ASUS P5B Deluxe/WiFi-AP LGA775 Core 2 Duo/...
ASUS P5S800-VM Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Mark Taylor
Mark Taylor
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
