Question about Apple iPhone Smartphone
Half top of the iphone works
Well im having a problem with the top part of the iphone 2g top half does not respond i already try pushing the hold buttom!put no luck can any body tell whats going on
  • Anonymous Mar 05, 2009
    I have the exact same problem, I was told to replace the whole front for the screen, it costs about $200 !!! Its more expensive fore the 2G .
What do you mean
Posted on Feb 21, 2009
Hello Expert. Hope you are fine. All sudden, i got problem with my Iphone 2G. my half screen icons from top side is not working where as half icons are working including icons in gray line which...
Your digitizer is broken, and with the 2G you will need to replace the entire screen to fix it. It is probably not cost effective to do so.
Mar 21, 2011 | Cell Phones
I dropped my phone today and now it wont work
When you dropped it you loosened up the digitizer connector which is number 2 under the screen. Open your iPhone and resit that wire firmly back in. That should fix the digitizer not working.
If its a 3G just unscrew the 2 screws at the bottom and use a suction cup to remove the screen. Easy. But if its a 2G then Good Luck.
Jan 29, 2010 | Apple iPhone Smartphone
The top half of my iphone wont work
The crack is why it is not working. I suggest taking it in for repair.
Nov 15, 2009 | Apple iPhone Smartphone
It's sounds like your iPhone is stuck in recovery mode
Try this
Sep 23, 2009 | Apple iPhone 3G
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
Unable to unlock my phone
Your device might have a problem in the touch screen.
In iPhone 2G the touch panel and the LCD screen are one unit that cannot be separated.
You shoud try to replace the iPhone screen with a new one and the problem should be fixed.
Aug 28, 2009 | Apple iPhone Smartphone
Battery issue still cannot be solved, hard reboot tried.
Have you tried all the resets:(if you have, bring back to the Apple store)
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jul 29, 2009 | Apple iPhone Smartphone
My iphone 2g gives a warning that the accessory is not made for
the sound on that device is not great I have been using a charger that says its not supported for over a year. But if you hold down the top and bottom middle buttom at the same time then power off it wll do a soft reset.
May 16, 2009 | BoxWave Corporation Apple iPhone 2G...
Bottom 4 Icons on 2G iPhone unresponsive
looks like a hardware problem....go back to the apple store or call apple.
Mar 25, 2009 | Apple iPhone Smartphone
Iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
Jan 02, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
