Question about Dell (8N816) Motherboard
I hav problem with my back light screen..
I hav dell laptop 600m inspiron ,at first i hav problem with back light screen,
and i hav show my laptop to near to loptop services ,he said that its problem with motherboard and now i want to know how much it will cost for motherboard .
  • 126 Answers
It will cost you around 760-780$
pls rate the solution
thankyou for using fixya
Posted on Feb 19, 2009
I have a Dell Inspiron 600m. When I turn it on it goes through the Dell startup screen and then a black screen appears with a blinking curser. That's where it stops. Tried reinstalling Windows XT but...
there are steps to resolve this issue ...
first of all remove all the usb devices and start the system and it should go to the desktop
shut the system back and start the system on the dell logo start tapping the delete key and that will take u on the bios screen there u will find USB emulation put it to no boot and save and exit and restart and than connect the devices to the system ... restart to make sure its working fine
Jan 22, 2011 | Dell Inspiron™ 600M PC Notebook
Inspiron 600m laptop flashes the red light at the bottom of screen as if it needs charged, but it is 100% charged and is not hot or anything. It flashed red three times then green. I powed down unplugged...
when you use battery power, does the laptop work or does the battery die right away try letting the battery die itself, like use the laptop till it dies then charge it up again
Apr 05, 2010 | Dell Inspiron 600M Notebook
I have a dell inspiron (600m) andi also have a dell flat screen television. i used to be able to connect my laptop and tv, so the tv would become a flatscreen. i would go to VGA and my laptop would appear....
I assume you would switch the TV's source to VGA. Is that correct?
Connect it the same way you did before, with the VGA cable. Then hit Fn + F8 on your keyboard, to switch the signal from your laptop screen to the VGA cable. Then select VGA as your source on your TV as you did before.
If that does not work, please post and tell us what type of television you have.
Mar 29, 2010 | Dell Inspiron 600M Notebook
Dell inspiron 600m is allways very hot. can't work on battery for more than 1 min. replaced battery - same problem. looks like the internal charger is shortening the circuts?? thanks, itai
I remember a recall on certain Dell laptop batteries due to their hot running.
Please confirm with your nearest laptop dealer ASAP as they have been known to catch fire!!!
Dec 22, 2009 | Dell Inspiron™ 600M PC Notebook
Dell inspiron 600m is extraordinarily slow
it may be due to viruses So please try to Run a good rating antivirus and Antispyware I hope this could help you out. Cheers
Jan 22, 2009 | Dell Inspiron 600M Notebook
Laptop won't dock
The inspiron 600M will not function in a D-Dock, but will work in a D-Series port Replicator. (Although the D600 and 600M share the same motherboard, the bottom plastics are different)
After trying the 600M in the D-Dock, it is possible the dock is damaged. I would undock the D630, then delete the docked profile. power off, dock, and reboot and see if it detects and works.
Jan 16, 2009 | Dell Latitude ATG D630 Laptop
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
Dell inspiron 600m sound drivers
Hi the easyest place to find all your drivers for your Laptop is to go to the Dell website.
here is a link to your model of Laptop Dell 600m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_600M&os=WW1&osl=en&catid=&impid=
Nov 08, 2008 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Dell (8N816) Motherboard Logo
62 people viewed this question
Alun Cox
