Question about Panasonic KX-FL611 Plain Paper Laser Fax
Drum life over and i changed the drum and tonner still have the message
How to reset drum replace panasonic 612
Posted on Apr 12, 2011
Drum life over
replace drum
Posted on Nov 03, 2010
Cannon ir 3025n some part not printed when printing or photocopying
Dear
pl. check the drum unit life, clean the drum and its cleaning blade.
Also check the developer roller for uniform toner flowing.
Thanks
Feb 14, 2015 | Cannon Office Equipment & Supplies
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
When i copy o print a document, it comes out with tonner and black dust stains, how can i clean it? Ricoh Aficio MP 1600
a) If possible remove the drum unit and see if there is a paper stuck in the drum unit.
To remove the drum unit first open the front and right door. Then remove the toner holder(green lock).
Then pull the drum unit out from the front of the machine(press the lock).
b) How many prints(copies) has the drum made ?
The life is 60000.If it has crossed its life replace it along with the developer.
Feb 16, 2010 | Ricoh Aficio MP 1600 Black and White...
My kyocera fs mita 1920 some dose not print or the message of add tonner come out while tonner was their why it do that?
remove the toner ... shake it well and re fix it and check ..... remove the drum unit and clean it ........ for more details please post your comment
Dec 29, 2009 | Kyocera Mita FS-1920 Laser Printer
After inserting tonner printer makeing noise
May be the drum is tight with cleaning blade. Please check it.
Nov 02, 2009 | Canon LASER SHOT LBP-2900 Printer
My Canon 2020 is putting a black line down the page not in the same place does this mean I need to change the drum unit
Plz. empty waste tonner from it and then clean it. it will resove your problem or check life of drum unit.
Jun 30, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Brother mfc-8460n prints black streaks
ithink . brother printer is best, we can always reffil untial drum isnot scarch, some time drum life is endinging as u say iit can be reset . after this we get 100% life. there is no need cheap and tools for reset it. reffiling before we reset cartage by adjusting cartage sides white ring. and we can also reset reffiling after . this treak is secre to tech.
Jun 18, 2009 | Brother MFC-8460N Laser Printer
Brother HL1250 won't print multiple pages
there are two reason behind the problem. 1.drum & 2.Fuser unit.
solution no 1.
In this printer the dram attache with the tonner. at first separate the dram unit from tonner. open the drum and clean the OPC carefully and also clean the blade. and re-assemble the tonner & drum. i think it will work for u.
solution no 2.
change the fuser unit.
Dec 01, 2008 | Brother HL 1250 Laser Printer
Problem in accepting the tonner by machine
This is a common problem. You need to be sure that the toner and drum unit are seated correctly. I assume you. You may also want to try a different toner in case the chip is bad on it.
The following has been known to work also. Open front cover leaving the toner cartridge and drum unit in.
Press the Options button,
When "Replace Drum?" comes up quickly press the Start button.
Immediately press the "1" and "0" button. The display will say "Accepted" and the error will go away.
You need to this these pretty quickly.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-FL611 Plain Paper Laser Fax Logo
1,577 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
