Question about Electrolux Guardian Bagged Canister Vacuum
Electrolux canister vacuum
Is there a blower port on this vacuum cleaner?
  • 1 more comment
  • Nicoh Feb 19, 2009
    It is Electrolux canister Model E 2100.
    I am in Barrie, Ontario
  • Nicoh Feb 20, 2009
    Yes, I found it! however, I was going to use it to try to unclog the centre vac hose. Looks as if it isn't a hose problem after all! Thank you.
  • royzee May 11, 2010
    Hi
    Whats the model number and where are you?
  • 134 Answers
Mmm cant find any info on this machine. Did you buy it in CAnada?
However. If you can find where the exhaust filter is, the bit where the air blows out, take off the cover and filter. If there is an exhuast blower it will be here.
I have to say that of late Electrolux have done away with this on most machines
Rob
Posted on Feb 19, 2009
How do I get the hose apart on an electrolux canister
Unplug it from the canister and try reconnecting it to the blower connection port
Mar 11, 2012 | Electrolux Guardian Bagged Canister Vacuum
What size vacuum bags does an Electrolux Ultralux 2000 bagged Cansister have?
It takes the "C" (canister) bags made by Home Solutions for Aerus Electrolux vacuum cleaners.
Apr 24, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Is there a blower port on the Lux 7000?
Yes. It's located beneath the accessory caddy on the back of the vacuum. Press the release catch on the rear of the caddy, and lift off. Remove the afterfilter, and there's the blower.
You can find a manual for this machine, and others at: aerusonline.com.
Dec 16, 2010 | Electrolux Guardian Bagged Canister Vacuum
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Model of BAg?
HI Your Exlectorlux uses Electrolux Style OX bags. Here's a few links back to our website to several different style of bags that will fit your Electrolux:
Genuine Electrolux Vacuum Cleaner Bags for Harmony Canisters
Generic Electrolux Style OX Vacuum Cleaner Bags for Harmony canisters
Hopefully this helped you! Please be sure to rate my repair helpful, or leave feedback if this was able to answer your questions.
Thanks,
Chris Jones
GoVacuum.com
May 02, 2010 | Electrolux Harmony Canister Vacuum -...
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Clog in handle/hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=579130
Clog in handle/hose
Posted by TCow on May 08, 2008
Small rubber ball got sucked up and is caught in the handle or hose. How can I take it part to remove the object?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. in some cases the Electrolux handle will come apart but id not then I use a couple of methods, if you have another canister vacuum or shop vac then turn on the Electrolux and the other canister vacuum and try to pull the ball out one way or the other. Or you can use a wire coat hander and create a little hook on the end and insert it into the handle portion of the vacuum to see if you can pull out the ball or loosen it so that it will roll out. One other choice that id you have a long small broom handle the length of the hose or longer and then you can push the ball out but the handle has to be smaller than the size of the inside of the hose and also be VERY CAREFUL… because it is an electric hose and it is very expensive so if you cannot remove the small ball bring it to a local vacuum cleaner dealer or the absolute last resort is to replace the hose, but most clogs can be removed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Help needed pronto!!
Most vacuums are make to suck not blow. Except for the Rainbows or Rexair vacuums. They have a port for blowing air.
Oct 30, 2007 | Vacuums
Electrolux Guardian Bagged Canister Vacuum Logo
245 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
