Question about GE JES1039 Microwave Oven
Model JVM163 microwave runs but does not heat
  • GE Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
My microwave over just stopped heating but runs like it is heating
hi , now that's either power supply to power the magnetron or the magnetron itself ...
Regards
Rob
Jul 15, 2015 | Kenmore Elite Microwave, Model...
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
Ge over the renge microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
Kenmore over the stove microwave will not heat 1996
YOUR MAGNETRON IS MOST LIKELY BAD. THIS IS THE UNIT THAT CREATES THE MICROWAVES.
Apr 11, 2009 | Microwave Ovens
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave makes deep humming sound and doesn't heat
Your magnetron that actually does the cooking is making that humming sound. That part needs to be replaced before it starts blowing your fuse inside the microwave. That part is the one located on top behind the control panel of your microwave and is about the size of a persons hand (sometimes smaller sometimes bigger). With everthing unplugged you can take the cover off and see it. It has some cooling fins on it and is held in place with only three to four screws. There are three to four wires that come out of it and go to only a couple of places one of them being a large capacitor that is about three to four inches long with terminals at its top. Find a magnetron at a local tv repair shop (reputable), a local electronic supply house (they can order you one) or on the internet. They cost from $25 to $60 depending on size of microwave. If you can do it yourself you can save about $40 to $50. Let me know how it goes. Good luck.
Jan 22, 2009 | GE JVM1631 Microwave Oven
Regarding microwave
Sanjay
This is due to the magnatron failing (this is the part of oven that cooks the food!) This is the most likely cause of y isssour oven not heating the food!
Magnatron needs replaced for oven to work again!
Please rate this free soultion!
Jan 18, 2009 | Sharp R-308J Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
GE JES1039 Microwave Oven Logo
198 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
