Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
My machine has indicated Download Standby all day yesterday and still indicates the same when I turned it on this morning. What can I do? I have tried to hold the reset button when I turned on the power, but it didn't work. I really need the machine. Help!!!!
  • 3 more comments
  • aaronwilliam Feb 20, 2009
    I HAVE SAME PROBLEM, WHERE IS THE RESET BUTTON?
  • mikewhitlock Mar 31, 2009
    I have the same problem and it has been this way 3 days. It will not perform any functions. Pressing copy, scan & start 3 times will not work.
  • jerry538 May 04, 2009
    I have the very same problem only mine says download all the time.Looking for answer please.
  • jhavona May 21, 2009
    MY COPIER KEEP SAYING DOWNLOAD STANDBY AND THE UNPLUGGIN FROM OUTLET/ POWER SWITCH TURN ON AND OFF DO NOT WORK.
  • amitayadav Nov 12, 2009
    I AM ALSO HAVING A PROBLE OF DOWNLOAD STANDBY AND I HAVE FOLLOW THE SOLUTION POSTED BUT ITS NOT WORKING, PLEASE HELP ME
  • 3 Answers
  • Unplug machine.
  • Press 1, then 9.
  • Plug machine back in.
  • Press 1, then 9 (again).
Machine should then initialize and be ready for service.
Posted on Jun 01, 2009
  • 100 Answers
If it does not work it needs a New image processor board and its around $400.00 retail cost. I work at a Canon dealer. Its the only real way to get rid of the problem.
Posted on Jun 25, 2009
OFF THE MACHINE AND PRES 1 AND 9 THEN ON
Posted on Apr 24, 2009
This solution worked for "Download Connected", may it will also work for "Download Standby"
With the machine on, unplug machine from surge protector or outlet. While the machine is off push the Copy, Scan, Start button in that order 3 times. Plug the machine back up. The machine should initialize and be ready to copy. Hope that helps!
Posted on Feb 26, 2009
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Does this model have a battery backup?
All smoke alarms that connect to your household electricity must be replaced every 10 years by code (NFPA 72). Chances are the device is indicating low battery, but it is time to replace it and all others of the same age. Check your local hardware store or call a licensed electrician to replace them.
Oct 06, 2014 | Home
2000 bravada worked ok yesterday went out this morning and won't start. Lights. radio and heater fan run and tries to turn over then just clicks. Could it be starter or alternator
The indication for your symptom is a dead battery, loose battery cable of a faulty ground wire. n If the battery is dead it could be an indication of a charging issue or there is some parasitic load or light that was left on
Apr 15, 2011 | 2000 Oldsmobile Bravada
Lenovo t400 cannot boot. have "z" light only
Hi vincent,
I see that you have a "z" light indicator on the system when powered ON but you see no video on the screen.
The "z" Indicator means that the system is turned ON and ready to use but is in standby mode.
To disable standby mode on your system simply press the FN button for about 5 seconds on the system make sure that the machine is turned ON, this will make you system go back to normal mode.
Note:
For additional info on the issue the system can be put to standby mode by holding down the FN+F4 for a second or two this will enable standby mode on your Thinpad T400 and to disable the standbymode press and hold down FN for 5 seconds.
I hope that this will be of help regarding you concern, have a nice day.
Mar 30, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Have had to replace lamp twice in the last two years on my Sony KDS-R60XBR1 HDTV. Yesterday I ended up with the four blinking red lights showing on the Power/Standby indicator nothing by the lamp...
hi,
fist of all try to reset ur tv. to reset do the following.
Turn on the TV. While holding down the up arrow button on the remote control, press the POWER (on off switch) button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
Dec 31, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My Windchaser fan model FTR184 does not work anymore - it did yesterday. The oscillator function still works but the fan doesn't come on. The red light indicating standby mode is lit. How do I get it out...
I have a Windchaser fan mode FTR184 also and it is in the same indicator STANDBY mode and now it will not come on and we have the remote, how do you fix this?
Jun 27, 2009 | Windchaser FTR163 SensorFan Stand...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Laptop intermittently turns off
I think this the virus problem have youantivirus with you otherwise please download free avg and scan your system
Thanks
T.Boopathy
Sep 15, 2008 | Computers & Internet
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
1,071 people viewed this question
old marine
old marine
