Question about HP Color LaserJet 8550dn Printer
"out of memory" message on a HP color laserjet 8550DN
I have a HP color laserjet 8550DN printer that is giving me an "out of memory" message. I have contacted a HP tech and he said to add more memory, which I did, but now the printer just sits there with rows of asterix on the menu pane? I shut down and took out the memory that I found and now it works ok, but still giving me that "out of memory" message?? What else can I do?? I used the same memory as the memory that is in the printer 32 MB, I have two in there which is 64 MB total and tried to ad 3 more 32 MB but the printer sat there with asterisks in the menu pane.
  • jbise Feb 20, 2009
    Yes, I used a memory stick from another HP printer that was b/w.
    I t was a 8150dn laserjet printer that I got the other pc 100 card from.
    Genius:
  • 2,120 Answers
Did you use GENUINE HP memory sticks?
It sounds like the memory is not compatible.
Scroll through the menus and select reset printer.
Posted on Feb 20, 2009
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
HP 8550dn printing to light
change the toner density settings
Aug 13, 2012 | HP Color LaserJet 8550dn Printer
8550 cold reset
Performing a cold reset 1 Print a configuration page to record the previous printer settings. 2 Turn the printer off. 3 Hold down GO while turning the printer on. Release GO after COLD RESET appears on the printer control panel display. COLD RESET (in English) appears on the display for one second to verify that the key sequence has been recognized, followed by the power-on self-test message. Once the power-on self-test is finished, the message RESTORING FACTORY SETTINGS displays in English.
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
On our HP8550 printer, we get three error messages. "Out of memory" (with no code), "40 EIO 1 Bad transmission" and "Drum kit low". It still prints (very slowly sometimes) and I've ordered the drum kit and...
Bad Transmission is a fault coming from your JetDirect network card.
Try reseating it. (With the power off!)
You could also try swapping it to the EIO 2 Slot. On the back of the device
(Again, with the power off!)
Comms errors will dramatically slow your printing, and can fill the memory with garbage.
Dec 22, 2009 | HP Color LaserJet 8550dn Printer
8550dn printer showing out of memory message? Is there a way to clear this without having to do all the resets? Or just how to clear the message?
If the error is '20.00 Insufficient Memory'
No action required. It is simply out of memory because the file you printed was too big.
If you keep getting the message, simpify the print job and/or add more memory to the device.
You could also..
Change the setting in the <Configuration Menu>, <Clearable Warnings>, from 'On', to "Job'.
This will get rid of the message a bit quicker.
Dec 08, 2009 | HP Color LaserJet 8550dn Printer
Message &quot;card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
My LaserJet 8550dn won't print
did you download the print drvers for the printer. the printer is not a plug & print . you have to download drivers. if you do not have the disc you can go to HP.com to get them. make sure that you download the postscript drivers it will alow you to print any font plus extras. hope this helps.
Nov 01, 2007 | HP Color LaserJet 8550dn Printer
HP Color LaserJet 8550dn Printer Logo
309 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
