Question about Samsung 226BW Monitor
Problem with Samsung SyncMaster 226BW
When the picture is dark, the screen slowly fades a bit out in contrast and the screen stars buzzing very low buzzing, but I'm able to hear it. Sounds like a coil that is not 100% fastened. When the image lights up again, the summing dissapears and the contrast is back to normal. I suspect the powersupply is starting to kick of, nd I would like to hear if anyone else has had this problem. (I have tried another display... No problem)
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Posted on Jun 12, 2009
Our samsung syncmaster 2493hm fades to black when on websites with dark color backgrounds. How Come? Is there a fix?
Its probibly the MagicBright settings, press the button next to the menu button (its down arrow) and change the settings to something else, i changed mine from "Dynamic Contrast" to "Game" and everything is as they should be now.
Jul 13, 2011 | Samsung SyncMaster 2493HM Monitor
I have a samsung moniter itts about 2 years old lately the picture keeps going grey like a lack of contrast,I have checked monitor leads i dont lose picture. I am a novice coulde it be my pcs graphics card...
If you mean by lack of contrast, that the screen illumination is low, then you probably have a faulty backlight, i.e. one or more of the cold cathode flourescent tubes is not working. Although this may be repairable, it may be more economical to buy a new monitor. Get a quote from a TV repair shop.
May 19, 2011 | Samsung SyncMaster P2450H 24" Wide TFT...
My tv is about 2 years old. It just started burning old images into the screen and they slowly fade away but its very annoying.
Removing burn-in takes time. The best practice is to avoid creating the images.
Whatever the image is coming from has been left on screen for an extended period of time. The TV should be turned off or the source turned off when not watching.
You may find some relief by lowering your contrast (which I am suspecting is still at or near 100% as they come from the store). Bring contrast down to, say 60. Use brightness or backlight to brighten the screen if you think it is too dark with the contrast lowered. (Best picture quality is near 50, the center of the scale.)
Jun 13, 2010 | Televison & Video
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
Samsung 226bw screen flickers/shuts off
it is a hardware problem. you can checked it from computer store.
Sep 07, 2009 | Computers & Internet
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Apr 04, 2009 | Samsung SyncMaster 2493HM Monitor
Syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
872 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
