Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Ps3 setting up static nat
I have forward the ports nd enabled static nat 2 my ps3 but when i do the connection test it says nat type failed!!! i can still sign in but cant play online, netopia router, wireless
Are you in ireland and with eircom?
Posted on Jul 15, 2009
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
My nat type is strict and when i try to play my PS3 i have connection issues. How would i get my nat type to be open?
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Mar 06, 2011 | Zyxel P660HW-D1 Router
I want to change my nat type and i have done 1000 things people tell me to and nothing works
port forwarding, you would have to call sony help line to get the port numbers and ranges, or set up a dmz with the same static IP as your ps3. Sony says that they preffer that people have nat type two while being connected to the network, but I noticed that nat type two does give me a moderate while in gaming mode, but Sony does not see that as any issue.. You have to set your up your ps3 with a static IP and configure your router the same way to your ps3 for DMZ.
Jan 18, 2011 | Linksys WRT120N Router
PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
On my ps3 i my NAT is set to 3 but i need it to be at 2 how can i fix this?
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB.
You will receive a warning letting you know that you will be signed out in order to perform the test.
You have Type 3, read on for help on opening up your NAT in order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB.
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy)from here, you will want to choose Manual IP Address Setting.
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test.
Feb 08, 2010 | Computers & Internet
Nat type fail ps3
You need to give it a static IP.
And forward these ports.
PORTS:
TCP: 80, 443, 5223
UDP: 3478, 3479, 3658
Follow these instructions.
Video walkthrough here.
May 11, 2009 | Buffalo Technology (WYR-G54) Router
Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
May 05, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Netopia router to strict
you need to open ports on your router so that it will give you proper connection to your ps3. you also need to set static ip address on your ps3.
here are the steps...
- go to a working computer that is wired to the router and open command prompt (for windows, click on start, then run, then type cmd or command, whichever will work, or click here if you are using mac)
- then you will be prompted with a black screen, on the blinking cursor type ipconfig/all
- take note of the subnet mask, default gateway, dns1 and dns2
- now go to your ps3 to set static ip adddress
* go to network settings and click network settings
* go to wireless or wired (whichever connection you are using for your ps3)
* then custom
* enter security settings
* now for your ip info click manual
* where it says ip address enter a static ip address (by default the ip address of your router is 192.168.1.254 so you can use any ip address that is on the same segment and was not being used by your other devices like 192.168.1.5 or 192.168.1.10
* subnet mask is normally 255.255.255.0
* put your default gateway number (the one that you have seen and listed from the command prompt) on the default router field
* enter the dns1 and dns2 also
* click next
* don't enable proxy server
* you can enable upnp if you can also enable it in your router
- now go bak to the computer and open a web browser, on the address bar of your web browser type the default gateway number (usually it's 192.168.1.254)
- you will be prompted with the netopia page, click expert modem on the left hand column, click yes, enter expert mode
- double click the word configure, go down and click on NAT, click static NAT, click the dropdown icon, see if your ip address (static ip address of your ps3) is there, if so click it, click on done, if this works, ignore the paragraph in brackets. (note: if it's asking for the default router ip address, you need to select/enter the default gateway number)
- click define custom service, click o port forwarding, select next , type anything in the service name, something that you will know its related to the ps3
- for global port range, if it's only one port that's being entered, enter the same port in the left and right hand boxes, in every case , enter the lower port in the box below saying base port even if there's only one port, and chage the TCP/UDP settings according to every port.
* here are the ports (note: repeat the same process for each one, after that window, select the static ip address you made in the drop-down list so it gets forwarded only for the ps3)
TCP port 80
TCP port 443
TCP port 5223
UDP port 3478-3479
UDP port 3658-3659
- when your done, click NAT on the left hand side, click the dropdown menu that has age of empires written on it and scroll to the bottom, click on the ports you made with the asterix beside them (*) and click enable , then enter the ps3 ip address in the bar , to enable them just for the ps3
- now click configure on the left and then click connection and tick the box that says upnp (note: you should have, when you click NAT on the left hand column, a static NAT address, enabled, it should be the same ip that you have used on your ps3, 7 ps3 ports, all enabled to the host device of your ps3's ip
- now , enter basic mode, click firewall, and set to low, this isn't dangerous as long as you have a desktop firewall such as windows or mcafee etc...
- save changes, and restart your router
hope this'll help you
ciao!
Aug 26, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
452 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
