Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error code 2 keeps flashing and the green on/off light.Immediately before this Error 5 kept appearing but now seems to have disappeared for no apparent reason. The printer will neither scan nor print.Help!
  • 544 Answers
Hi,,
please try first to turn it of after that check your connection plug to CPU and printer...
let me know if it is work or not..
thanks,
Posted on Feb 19, 2009
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,jimvincentvillanueva@yahoo.com
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
    Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
    Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
    Constant blinking green power light but doesn't turn
    This is from my WS65907 service manual.
    4. Self Diagnostics
    The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
    1. Initial Control Circuitry Check
    Immediately after the TV is connected to an AC power source:
    • The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
    properly.
    • If the LED does not flash ... the Microprocessor is NOT functioning.
    2. Error Code Operational Check
    Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
    activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
    has occured since the last Initalization.
    Note: The front panel buttons must used, NOT those on the Remote Control.
    • The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
    • The flashing then pauses for approximately 1/2 second.
    • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
    • The Error Code is repeated a total of 5 times.
    Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
    3. Error Codes
    The Error Code designations indicating a malfunction, or no malfunction, are listed below:
    “12” ... indicates no error has occured.
    “21” ... X-Ray Protect circuit.
    “22” ... Short Protect circuit.
    “23” ... Horizontal Deflection failure.
    “24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
    Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
    be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
    and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
    Apr 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
    Kyocera Ecosys FS 920
    There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
    1) Green On, Red Off = Printer Ready.
    2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
    3) Green Fast-Flashing, Red Off = Printer off-line.
    4) Green Slow-Flashing, Red Off = Processing Data.
    5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
    6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
    7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
    8) Green Off, Red Off = Printer power is off.
    9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
    10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
    So what is your printer condition? Better know what is going on your printer so can solve the problem.
    YBC (/\)
    Mar 24, 2009 | Kyocera FS-920 Laser Printer
    Canon i560 Ink jet Error Code 5C00
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    May 05, 2008 | Canon BubbleJet i550 InkJet Printer
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    61 people viewed this question
    old marine
    old marine
