Question about Kenmore 44102 Front Load Washer
My kenmore is leaking, but they told me they had never had to replace the rubber on one before. Someone told me that there may be a catch that you have to empty every so often but i can not find one. anyone else have this issue?
  • dsuldesigns Mar 29, 2009
    Kenmore 44102 Front Laod washing machine leaks only on the spin cycle... anyone else have this issue?
  • cam8897 May 19, 2009
    I have leaking from around the very bottom bolt which holds the 2 tub halves together. Only while spinning, I can tell it's loose. Do those bolts simply thread into the drum material (hard plastic)? or is there a metal threaded insert which the bolt tightens into? It feels tight right now and I'm afraid to torque too much in case I end up with a handful of broken plastic in my hand!! Is it best to loosen first, then tighten? There's a bit of corrosion on the bolt head. thanks
  • 188 Answers
There is a coin trap built into the drain boot but it will not leak if there is something in it.
There are several places the water could be leaking from, the first thing is to try and locate the source by removing the front kickplate panel and visually inspecting.
Here are some places to check...
-Inspect the door seal (bellows) for holes/tears
-Inspect the drain boot (rubber boot connecting drum to drain pump) for a loose clamp or holes/tears
-Inspect the tub bolts which hold the 2 tub halves together. Remove the top of the cabinet and look for a gap between the 2 drum halves. Feel your way around where the tub halves join. If you feel water or see soap residue tighten ALL the bolts.
-Inspect the drain hose (inside and out) for any holes
There are a few others but those are the most common.
Let me know if that helps. Good luck!
Posted on Feb 19, 2009
My kenmore 400 washer is leaking from the bottom, What could it be how can i fix it?
When you don't look yourself, or invite someone to look, you never will know what is wrong. Can be everything from a bursted rubber hose, a loose hose or even a needle piercing through a hose. I have seen so many different causes for leaking, it could be none of the ones I mentioned here is the cause in your machine.
Sorry, but I can't make more from this.
Feb 16, 2015 | Kenmore Washing Machines
My brakes are almost to the floor and the emergency brake light was on intil i put fluid but it is leaking the brake fluid back out i can it leaking behind the tire the leak is on the front passanger side...
Not a sealant, but a rubber hose in the brake line going to the tire. If the hose is ruptured, and it probably is, the fluid will leak out. Take the wheel off to see. The hose will need replacing, then the brakes will need bleeding to get all air out of the lines.
Nov 30, 2013 | Cars & Trucks
Rubber door seal has hole in it
Mine too. I know that's not very helpful but after looking into what it would take to replace even if DIY, I decided to give the seal a real good cleaning, always wipe it down after each use, and place a small plastic container on the floor to catch the leaks which weren't quite as bad after keeping the seal more clean.
Sep 20, 2013 | Kenmore Elite 45986 Front Load Washer
I was told that my Toyota Highlander has leaky sway bar links that need to be replaced. Another Toyota dealer said they are fine and there isn't anything to possibly leak in a sway bar link. Not sure...
On the suspension the only thing that can leak are rack and pinion, shock asorbers,and motor mount and axle boot.there is no fluid in sway bar you need to find someone who will show you and who you trustcansmo_152.gifcansmo_153.gifcansmo_154.gif
Aug 29, 2011 | 2003 Toyota Highlander
My 99 chevy malibu takes a while to start. it sounds like its trying to catch but it takes a couple of tries. someone told me it was the starter. does that sound right?is so where would it be located?
define trying to catch. is the engune turning over but sounding like it may start then finally does? or does the starter spin but the engine is not turning unless you turn the key to start a few times if it is the latter it could very well be the starter. check to see if you have an oil leak onto the starter. if it very greasey then you will need to adress the oil leak too. the starter is located on the lower right side of the engine. (passanger side.)
Nov 11, 2009 | 1999 Chevrolet Malibu
Kenmore 74812 Gas Dryer. Was told it ignites,
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Jun 22, 2009 | Kenmore 74812 Gas Dryer
Kenmore 70 series Washer- Water overflows
The most likely cause is a split or cracked hose to the water level knob on the front panel. To get to it, take a putty knife and slide it into the front corners between the lid and the front panel to pop open the spring clips. Flip the top back and follow the little rubber hose from the control panel down to the bottom of the tub. Loosen the spring hose clips and pull the hose off. Check carefully for cracks or splits and replace if needed, which it most likely does. If you found this helpful please don't forget to rate it. If it doesn't help, forget we ever had this discussion (just kidding).
Apr 16, 2009 | Kenmore Washing Machines
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore 44102 Front Load Washer Logo
256 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
