Question about Intel Motherboard
Unable to install windows XP ,after the hard disk is formatted
Able to run bootable Knoppix linux from cd.
I have a SATA harddisk
    President:
  • 2,653 Answers
Try using a safe boot. When the knoppix menu comes up type: failsafe
If memory serves me correctly there is a list of different modes, otherwise type: /?
or help
Let me know what happens or if you need more help.
Posted on Feb 20, 2009
MY QUESTION IS HOW DO I Disable the "SECURITY FREEZE LOCK" on my hitachi HTS54503289a300, 320 GB sata hard Drive? originally WAS INTALLED IN MY ACER TRAVELMATE LAPTOP NANUFACTURED IN 2012 BUT THE LAP
Maybe if you can format the disk-but you loose data, maybe there is a program that can do it, probably in linux, or bootable itself, maybe ask acer for master password or something, if you still own original laptop and it runs then try to remove disk encryption while the hdd is accessible with laptop (i think its in bios), otherwise the hdd may be unusable to prevent data theft. you can plug any sata hdd into any sata device if you can hook all the cables, no compatibility issues there. try googling and youtubing for more answers
Sep 14, 2014 | Computers & Internet
Acer Aspire 4315 when i formatted the it is shown hard disk drivers not detected quit or restated the system.
If you are formatting this model Acer usinf the Windows XP installation CD then Windows cannot detect the hard disk because this Acer uses a SATA hard disk and Windows XP cannot detect a SATA hard disk. The Windows XP installation CD does not include a SATA driver in this CD.
To format and install Windows XP on your Acer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
May 01, 2011 | Computers & Internet
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
XP not detecting MY HDD but 7 trail and linux freeware
Method 1 : Go to BIOS and set anything with SATA disable (usually find uns=der advance setting in IDE configuration setting).Save the setting.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Jan 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
I am getting a blue screen with error message: stop: 0x000000024 (0x00190203, 0x8A7DC5B8, 0xC0000102, 0x00000000) message I have run many diagnostic tests and all come back normal. it will not start in...
You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
  1. Download nlite from http://www.nliteos.com/
  2. Download drivers for that laptop
  3. Download service pack 3 for windows XP
  4. Install nlite for windows XP and run
  5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
  6. Burn ISO Image
  7. Install Windows XP
  8. Good Luck
Nov 25, 2009 | HP Pavilion dv5-1140us Notebook PC
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Mar 09, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Do i need to change my harddisk?
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Feb 08, 2009 | HP Pavilion dv6000z Notebook
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
Sata
You must disable the native mode for the SATA in setup mode.
***NOTE*** be sure that you have all of your drivers for the SATA and all drivers for windows xp before beginning.
Mar 12, 2008 | Computers & Internet
Intel Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
