Question about Sony KV-29LS60 29" TV
Sony tv kv-xj29m80 need to know what error code 2 means
    Welcome Back:
    Visited the website for 2 consecutive days.
IN THIS SONY TV KV- XJ29M80, IM FACING A PROBLEM THAT SET GOES TO ERROR MODE WITHIN FEW SEC'S AFTER GETTING IT ON, AND THE LED INDICATES 2 BLINKS AND GAP AND AGAIN 2 BLINKS AND CONTINUES..PLZ HELP ME ...I WAS FOUND THE HORIZONTAL OUTPUT TRANSISTOR BLOWN AND THE 1.2 OHM RESISTANCE ALSO FOUND BLOWN...I REPLACED THE BOTH BUT THE PROBLEM IS CONTINUE...
Posted on Oct 20, 2010
Sony trinitron model no KV-XJ29M80 continuously blinks red light and relay makes sound whats the problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 20, 2016 | Sony Televison & Video
My sony kv-27fs13 has a problem .. the standby light flash 4 times . What is it ?
Hi there
In sony tv`s the 4 blink code(sony error codes)usually indicates a vertical deflection problem.
Your vertical output i.c and/or related components are probably faulty and need to be replaced.
If you feel that your up to repairing it let me know and i`ll see what i can do to help.
Merry Christmas
Dec 24, 2009 | Sony KV-27FS13 27" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Out of service, blinking light 6 consecutive times
The six blinks code (sony tv error codes) indicates a failure in the horizontal circuit,which means that some faulty components needs to be replaced before it will turn on again.You might need the help of a local tv repairman. Hope this help Good luck.
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Nov 30, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony KV-27FS100 No Picture
Check Horizontal Output Transistor, if found bad / short, replace it.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV
Blinking what - how many times before it pauses and then blinks the next set?? Sonys have an error code of blinking to help isolate the problem... (count the number of times it blinks before pausing and let me know).
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27S42 Television won't turn on
NO -the tube will be fine . The TV is in 'protect mode' . THis means that it has shutdown because of an internal fault condition. THis TV needs a technician's love..
Sep 17, 2007 | Sony KV-27S42 27" TV
Sony trinitron kv-27fv17
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby, this means there is a component inside your TV set, in the main power supply or the sweep power supply that is not letting the TV set's power supply regulate properly. I'm sorry to say, there is no quick fix for this and is going to need to be diagnoised by a trained tech. Good Luck
Mar 19, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-29LS60 29" TV Logo
430 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
