FixYa.com
Tags:
IBM VMware ESX Server   for PC, Linux
ESX remote console is wary slow, and disconnect...
By Hart - usenet poster
I am using an ESX 2,5, and have serveal virtual windows 2003 servers.
When using MS remote desktop or Dameware everything works just fine.
But when I use the ESX remote console, it is wary slow and disconnects
often. It is almost useless :-(
What is wrong, is it my network connection?
Is it possible to "tune" the ESX remote console?
Any best practices for implementing the remote console?
/C
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In this case the link speed & negotiation options don't seem to be a factor.
Everything works the same regardless of whether it is locked down or
allowed to auto-negotiate. Anyway, VNC and Windows Remote Desktop [via RDP]
into any of the guest Win2K3 SP1 servers running under VMware ESX & GSX on
this particular piece of server hardware works properly. It is only the
VMware Virtual Machine Console that has performance problems. If there were
some sort of low-level media problem, I'd expect TCP/IP performance to be
impacted equally for all applications that run over TCP/IP, but that's not
what I'm observing. All guest system console access via VMware Virtual
Machine Console is terribly slow over the LAN and is completely unusable
over the Internet via broadband connections & a T1 pipe at the server end.
All access to the VMware host system seems to function OK, as does file
system access to the guest systems and remote console access via VNC and RDP.
This is was happening with the current build of ESX server, and we then
re-built the server using GSX server and had the same problems. We have
another identical piece of server hardware that's already running GSX server
on top of Win2K and there's not any sort of similar problem there,
although the guest systems are only Win2K & WinXP. It's the newer GSX
server installation on top of Win2K3 SP1 with all Win2K3 SP1 guest systems
that's having the performance problems.
Chuck Chopp
ChuckChopp (at) rtfmcsi (dot) com #
RTFM Consulting Services Inc. 864 801 2795 voice & voicemail
103 Autumn Hill Road 864 801 2774 fax
Greer, SC 29651
"Racing to save lives"
The Leukemia & Lymphoma Society - Team in Training
Do not send me unsolicited commercial email.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
We had slightly different problem (could connect to the ESX management
interface via HTTP but Virtual Centre wouldn't connect) but I would
agree with Don about the link speed stuff. The autodetection of line
speed is a common problem I see across a range of OSes. I do most of
my work with HP Proliant servers and Cisco switches but I don't know
if the problem is specific to either or both of these platforms.
I found the following article very helpful. Just one note, the link
speed change didn't seem to take effect on restarting the interface as
detailed in the document, the ESX server needed to be rebooted.
Solution #3
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
I had this problem and it was because there was a mismatch between on
network card and the switch. The switch was set to a 100/full my card was
on auto (it was a Gig card). Once the network guys change the switch to
auto the problem went way.
Don
Solution #4
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
I've had this problem before with the remote console disconnecting.
- Turned out to the the network card settings for the service console.
You can amend these by logging into the service console and editting
the file /etc/modules.conf.
See -
Solution #5
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
Hi there..
I have had the same problem. The only tweak I have found so far, is to
set "Allow unencrypted VMware Management Interface and Remote Console
sessions" in the MUI.
Not perfect solution at all, but it helps :-)
JF@DK
Solution #6
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
I've had the exact same problem with the VMware Virtual Machine Console,
both with ESX v2.5 and with GSX v3.2 when running Win2K3 guests. The
virtual console is so slow - mouse movement lags - keystrokes are "delayed"
- that it is almost unusable via a LAN connection [1 gigabit ethernet], and
via the Internet [thru the firewall, over a DSL connection], it is
completely unusable.
I posted about this on the GSX server news group and still haven't received
any sort of meaningful responses.
Chuck Chopp
Greer, SC 29651
Can you Help with these Network Management Tools problems?
dhcp relay source code
Hi , I am in very much need of... Answer This...
drag nat spk med solutions 8
Vista new computer - message... Answer This...
sagem my850c need solution
Dear sir. i got gift from... Answer This...
reparing apple ipod
do not display mp4 player Answer This...
engineering drawing 1
how to care for drawing tools Answer This...
Repair Service
Find Network Man. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
