Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet how to enter diagnostics
Whirlpool duet washer how to enter diagnostics
  • Anonymous Mar 30, 2014
    washer will not shut off
Look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
Posted on Feb 19, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlepool duet front load washer error codes F01 and E02
Whirlpool Duet Washer model number WFW94HEW2
My wife put a bunch of wet towels in the washer after this we got Codes F01 E02. I freaked out.
Under the top(roof) panel of machine there is was a service technicians manual that explain how to enter Service Diagnostic mode and explained fault/error codes and their possible causes. This isnt for the faint among us. But if you can solder and work with electronics you can diagnose the problem. The technician manual tells you check this, then this and if that doesn't work/ or does work go to 'C', then go to 'D' etc. Either way I ended up diagnosing that it was my MCU (motor control Unit), you did have to use my multi-meter, for ohms and resistance, but it wasn't rocket science. Upon close observation there was a burnt connection solder point on the board. I looked up the part online and ordered, wasn't cheap. $225.00. But just to come diagnose the machine Whirlpool was going to charge $100.00 + parts and whatever else. The moral of the story is if you can tinker and be careful you can totally do this.
Jul 23, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Jan 17, 2010 | Whirlpool Dryers
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9600T Washer - How do I run diagnostic mode?
Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CONTROL LOCK LIGHT ON. CANN'T USE WASHER.
pull plug wait 5 minutes then plug back in go into diagnostics
close door
push control/on
select drain/spin
select no spin by pushing spin speed touch pad
push prewash optionj four timesw within 5 seconds
c:00 will light up
in order to advance to next step
push prewash option 2 times
if it does not enter diagnostics you must replace main control board
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Just installed whirlpool duet front load, no lights, no display
sounds like whirlpool, but yes is not an error code. try diagnostics, press any option key 4 sec on 4 sec off 4 times from off and should enter diagnostic and show real code
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,041 people viewed this question
Dan Webster
Dan Webster
Sal De
