Question about Apple iMac G5 Desktop
HD Temp.Sensor problem
Received an error message in Apple Service Diagnostic - Ambient Temperature error -25128
so I replaced the HD temperature sensor and cable but still get the same error when I run Apple Service Diagnostic again. The Hard Disk Temp.Sensor does not show up in Temperature Monitor or iStat. Computer behaving well mostly but sometimes will not startup, stays on black screen with front light on.
iMac G5 20" PPC 1.8 ghz V.1 2005
  • marieyates Apr 05, 2009
    Yes, I know there is more than one sensor in the unit - the others are all showing fine in Temp Monitor
    I replaced the HD Temp monitor and cable but it still does not initialize at Startup and fan is running slowly all the time - I can feel it - any suggestions? CPU and SMART sensors showing up nicely and working fine.
  • 55 Answers
There is more than one sensor in the unit, the other two are part of the logic board and can't be changed unless the logic board is changed.
Posted on Feb 22, 2009
Where is the ambient temperature sensor located ?
images for 2008 Chevrolet HHR LT Where is the .
Outside Temperature Sensor - Chevy HHR Network
www.chevyhhr.net/forums/...hhr-4/outside-temperature-sensor-30594/
Jul 9, 2010 - I had the outside temp sensor go on my 99 Buick. I don't know where it islocated on the HHR, but it was just a plug in sensor. Take out the old, stick in the new.... 2008 HHR LS 2.2 L Auto Built: 12-19-2007. Bought: 4-26-2009 Location of the ambient engine temperature sensor.... Help ...
Mar 26, 2013
Engine Temperature Sensor
Oct 6, 2011
Outside Temp Display
Dec 19, 2008
Outside air temperature problem
Oct 30, 2007
More results from www.chevyhhr.net
Jan 25, 2016 | 2008 Chevrolet Chevrolet HHR LT
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
We're is the coolant temperature sense located on a 2008 trailblazer lt
Hi Janice , Before I say where the coolant temp. sensor is I'd just like to make you aware of a couple of thing's before you replace this sensor needlessly .It's one thing if you have a DTC diagnostic trouble code for the sensor but another if your temp. gauge isn't work ! You see the coolant temp. sensor is an input to the engine computer , not directly to the temp. gauge.
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine coolant temperature. The engine coolant temperature gage defaults to 100°F (40°C) or below if: ?€¢
The ECM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of serial data communications with the ECM.
Jan 01, 2016 | 2008 Chevrolet TrailBlazer LT
My outside air temp is reading at -40 on my 2008 Pontiac Torrent. What is the right sensor and where is it located?
Ambient Air Temperature Sensor (UH9)
At the front of the vehicle, at the lower left side of the front bumper bar
Pin
Wire
Circuit
Function
A
0.35 L-GN/BK
735
Ambient Air Temperature Sensor Signal
B
0.35 YE
61
Low Reference
Jul 22, 2015 | 2008 Pontiac Torrent
What does the code E5 mean on my fridge freezer? It's turned on but not working.
E5 on Freezer Display Ambient temperature sensor error Unplug the refrigerator and check the wiring connections in the ambient temperature sensor circuit. If the wiring connections are okay, replace the ambient temperature sensor. If the problem persists, replace the electronic control board. Ambient temperature sensor, Electronic control board
Mar 21, 2015 | Refrigerators
Error code 5E
The means the temperature is higher then the set temp. Check the door and set the temp higher
Mar 26, 2013 | Samsung RS2630SH Side by Side Refrigerator
Replacing oven sensor on GE Range JGSP31GER1WG
You can try the new thermostat and if the temp is still off, then you you will need to replace the control.
Dec 29, 2011 | Whirlpool Stove Oven Sensor 8053344
Put trans in works great but has a code po 0700
P0700 is a generic fault code indicating a transmission problem. It's possible it's a left over code from the bad transmission you replaced. You may need to have the code cleared at a transmission shop that uses a different code reader to clear the code. Unfortunately, unlike the standard OBDII code reader, the transmission codes don't always reset themselves after a repair is made.
Oct 13, 2011 | 2000 Jeep Cherokee
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
99 oldsmobile intrigue
The ambient temperature sensor going bad causes this exact problem. I've replaced many of them because when they show outside temp as being below 60 degrees, the A/C control module will shut the compressor off.
Aug 07, 2008 | 1999 Oldsmobile Intrigue
Apple iMac G5 Desktop Logo
692 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
