Question about Microsoft Visual Basic 6.0 for PC
How to enable the registry
I ned to know how to enable the registry editting
  • Anonymous Feb 22, 2009
    My software does not start, massage show do not start its having a code, and microsoft connection jet engine.
    Scholar:
  • 77 Answers
Download this file and double click it:
http://www.kellys-korner-xp.com/regs_edits/regtmcmdrestore.vbs
It will restore the registry editing if some virus/malware blocked it.
HTH,
Deboo
Posted on Feb 19, 2009
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
Tip
How to Solve " Registry Editing has been disabled by your Administrator"
Methods to Remove the Registry Editing Restriction
Method 1 :- Using REG.EXE Console Tool
  • Click Start, Run and type this command
REG add HKCUSoftwareMicrosoftWindowsCurrentVersionPoliciesSystem /v DisableRegistryTools /t REG_DWORD /d 0 /f
You should be able to launch Tweak UI, as well as the Registry Editor.
Method 2 :- Using the Group Policy Editor (Windows XP Only)
  • Click Start, Run and type gpedit.msc and press Enter
  • Goto the following location User Configuration | Administrative Templates | System
  • Double-click Disable Registry editing tools and set it to Not Configured
  • Exit the Group Policy Editor
Note:- If the setting already reads Not Configured, set it to Enabled and click Apply . Then revert it back to Not Configured. This ensures that the DisableRegistryTools registry value is removed successfully.
on Jan 12, 2010 | Computers & Internet
Hii,, i hv made some folders hidden ..and now when i am trying to unhide i m not able to find folder options.. my operating system is vista home basic.. when i am typing regedit in search option it is...
Here are the some steps you can do to enable your folder option .
To enable REGISTRY EDITING
Type gpedit.msc in RUN dialog box and goto: User Configuration -> Administrative Templates -> System
in right-side pane, set "Prevent access to Registry editing tools" to either Not Configured or Disabled.
Type regedit in RUN dialog box and press Enter. it'll open Registry Editor, now go to following keys:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Current Version\Policies\Explorer
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Current Version\Policies\Explorer
In right-side pane, check whether a DWORD value named NoFolderOptions exists or not? If it exists, delete it.
2. If you don't want to do any registry editing and are not familiar with editing the registry, then you can simply download following file, extract it and then run the .REG file:
DOWNLOAD FOLDER OPTION REGISTRY FILE
Jul 17, 2011 | Computers & Internet
How to activate task manager on my pc
It can be done easily by editing the registry. I will try to explain in detail. Follow these steps
1. Check that your PC is virus free. Install Antivirus program if required.
2. Regisry is enabled. Goto run command from start menu OR Press Win key+R and type 'regedit'. It would show up registry.
3. If registry is enabled you can edit it.
4. Open notepad and paste the following four lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
"DisableRegistryTools"=dword:00000000
5. TYPE the file name ENABLETASKMANAGER.REG
6. Choose 'all files' option from 'Save as type'
7. Now you should have a registry editing patch. Please note that its extension is .reg
8. Double click the patch to add it to registry and task manager would be enabled.
9. Alternatively, you can download PROCESS EXPLORER, whichis a replacement of task manager from internet. It works even if the taskmanager is disabled.
Hope this helps. Let me know if you need any further clarification/ help
CreativeTECH
Nov 12, 2010 | Computers & Internet
My task manager doesn't work anymore can u help me fix this?
Try this:
If Task Manager has been disabled, you can re-enable it if you have administrator privileges on the computer.
To enable Task Manager on a computer running Windows Vista Home Basic or Windows Vista Home Premium This procedure requires you to edit the registry. An incorrect change to your computer's registry could render your computer inoperable. We strongly recommend that you back up the registry before making any changes. For more information, see Back up the registry.
  1. Open the Registry Editor by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, typing regedit into the Search box, and then pressing ENTER. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Navigate to the following location: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies
  3. Double-click System, double-click DisableTaskMgr, change Value data to 0, and then click OK.
To enable task Manager on a computer running other editions of Windows Vista
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, type gpedit.msc in the search box, and then press ENTER.
  2. Under User Configuration, double-click Administrative Templates.
  3. Double-click System, and then click Crtl+Alt+Del Options.
  4. Double-click Remove Task Manager, click Disabled, and then click OK.
or you're computer might be infected by a virus, if you're not the one who disabled the task manager.
Try to scan your computer also.
May 08, 2010 | Microsoft Windows XP Home Edition
How to enable registry editing? plz help me,,tnx
You are really not giving enough information to be of any help.!!
If you need to edit your registry, you must know what you are doing or you may invoke a problem in which you cannot repair.
If you still wish to edit your registry, type regedit from a command box and you will be their.
Please rate....
Oct 20, 2009 | Computers & Internet
***** problem? it wont be recognized by compute, why oh why??? can you please help
try to change ur jumper setting of ur cd rom drive,set into master mode or slave mode! and try to change ur cd rom cable also.. check ur bios if ur cd rom drive is enable.
Jun 19, 2009 | Toshiba (P000242100) Internal 14x CD-ROM...
Re.Launching Registry editor,To Cure CD-DVD-writer not Responding
Are you the Administrator, and do you have the Administrator's password?
If so, then log in as Administrator and make the necesary changes.
However, if not, then you must reinstall the OS, to establish yourself as such.
Apr 17, 2009 | ASUS DRW-1608P DVD±RW Dual Layer...
REGEDIT
regedit - to disable this file from running, delete it. if you want to turn off the registry, boot computer into safe mode (tapping f8 key while booting). if you need to manually uninstall a program, do an F3 search in the registry for the program name as a search string. there can be as many as 500 registry entries for the program... if you adopt the f3, delete, enter, f3, delete, enter, you may be able to uninstall the program's registry entry in as little as 15 minute to 1 hour... best of luck, I am not responsible if you delete a wrong value and crash your computer .... heheheeheheh.
Sep 26, 2008 | Red Hat Enterprise Linux ES 3 Standard...
Win32NT-5.1.2600.0
Hi Gargamel,
That's your windows operating system version popping up. If you click on START then RUN and type in (w/out the brackets) [winver], that is likely what you'll see.
Are you running Microsoft TweakUI for WindowsXP? There's an option in TweakUI to Enable (or disable) "Show Windows Version on the Desktop".
I don't know how it got enabled on your new XP build. It normally isn't enabled by default. But you can most likely disable it by installing TweakUI and, 1st, selecting the option, and 2nd, deselecting the option to "Show Windows Version on the Desktop".
See HERE.
You can download TweakUI from HERE. Look in the right hand column. Scroll down 'till you see TweakUI.
There's a registry edit for this, too. I'm cautious, though. I don't normally recommend registry editing unless the person is experienced in it. If you are, please, let me know and I'll pass that on to you as well.
Thank you
BJ @:)
Apr 14, 2008 | HP LaserJet 3050 All-In-One Printer
Microsoft Visual Basic 6.0 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
