Question about HP LaserJet 4350 Printer
Reciving error 49.FF95SERVICE ERROR ON BOOTING THE PRINTER, EVEN WHEN COLD RESET IS DONE IT DOESN'T CLEAR.
    Genius:
  • 2,120 Answers
Remove the memory.
Pull out the formatter cage
Remove the network card
Reinstall all items removed
Posted on Feb 20, 2009
No display clean ram and switch on ok but not reddy 49.FF05 ERROR in valied nand key press any key
ISSUE: A 49.x service error appears on the HP Color LaserJet 4500 or 4550 printers display, and other unexpected errors may be displayed such as:
  1. Turn the printer off, and then turn it on again. If the 49 error clears, proceed to Step 9.
  2. If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card, which is located on the formatter, (see Figure 1 for location), or any third-party devices, if installed.
  3. Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
  4. Turn the printer on, using a cold reset. If the 49 error returns, turn the power off, and unplug the printer. Remove the formatter, and check that the parallel I/O board is firmly installed on the formatter board.
    NOTE: To perform a cold reset, turn the printer off, and hold down the GO button while turning the printer back on. Remember to remove the Jetdirect card (if installed) before performing a cold reset. (The Jetdirect card is located on the formatter).
Mar 28, 2013 | HP LaserJet Office Equipment & Supplies
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
I have a error 49 when the machine comes up and blank screen with just the fan running ervery other boot up . i thinkit maybe the formater board
A 49 Error usually always points back to the formatter, however I would at least attempt a cold reset here are the directions:
1. Turn off the machine
2. Simultaneously press and hold the Cancel button and the right arrow button (> ), and then turn on
the machine.
3. Wait until the message Permanent storage init. appears, and then release the Cancel and right
arrow buttons.
Once the cold reset process has been completed, it will either show you a 49 error or ready.
If the cold reset does not fix the 49 error then yes I agree replace the formatter.
Oct 20, 2010 | HP M2727NF Laserjet Printer
How to solve error 4900ff on hp 4015 printer
The LJ4015 Series printers are the latest upgrade of HP's most reliable LJ4000 series printer. . 49.xx errors are usually firmware, formatter, or sometimes print-job related.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. The newest firmware is version 04.046.2A released in early September.
Critical Firmware Error.
Causes are invalid print commands, corrupt data, invalid operations or even a bad formatter.Power cycle the printer. Press STOP to clear the print job from memory.
Power cycle again. Try printing something from a different software program. If it works, print the job that failed before. If it still fails, repeat the power cycling again and then print something using the failing program but a different file. If it works the file that failed before is corrupt.
If it fails no matter what you print, your printer has a hardware problem and would suggest going to HP for warranty. Try updating the firmware.
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off (Remove the Jet Direct Card - Retains IP Address)
  1. Turn the Machine on.
  2. Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
  3. Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced. Formatter Part Number - CB438-67901 for HP LaserJet P4015x (HP CB511A)
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Oct 04, 2010 | HP LaserJet P4015N Printer
I have a HP laserjet 4015 and it shows a 49ff04 error.
TF
Jun 17, 2010 | HP Laserjet P4015x Printer
We have an error 49.2 F83 come up on our HPLJ 4015n, How do I fix this and what is causing this?
1- Turn the Machine on.
2- Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
3- Arrow up to cold reset then hit OK to start the reset.
TF
Feb 26, 2010 | HP LaserJet P4015N Printer
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Hp 3050 error 49
on the menu setup and then mover to usb opption. choose full usb (do not choose hight usb) now ii's ok!!!
Jul 03, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 4350 Printer Logo
203 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
