Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
How do you turn off SAP? When I clicked on MTS, STEREO-ON AIR SAP - ON AIR & MONO appeared. When I hit ENTER it dropped to SAP -ON AIR. The arrows around ENTER don't move it anywhere and if I hit ENTER again it moves down to MONO. Can anyone help me please?
tvtek
  • 1284 Answers
SOURCE: SAP - I can't get my new TV out of Mono and into stereo.
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
Posted on Feb 13, 2007
SOURCE: MTS keeps switching...HELP!!!!
Any Luck???
Posted on Apr 21, 2008
  • 16 Answers
SOURCE: Akai LCT2070 Stereo Sound
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
Posted on Sep 24, 2008
JTC13
  • 17 Answers
SOURCE: sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Posted on Feb 19, 2009
landsend
  • 1066 Answers
SOURCE: mono stereo sap on screen
you need to reset the preferences on you sound icon in the menu panel
Posted on Mar 26, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
I think that my TV soney braiva xbr has an issue with SAP but some ch. are in spanish some do not have sound How do i reset this tv?
Press MTS/SAP on the remote (under the number buttons) to go between the 3 options of STEREO or MONO or AUTO SAP. Not all channels will have SAP (secondary audio program). Selecting stereo should eliminate any secondary audio.
Mar 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
I am getting SAP or Spanish on some stations. How do I change or remove that feature?
Press the Stereo or MTS button on the remote control until the words STEREO appear on screen. There usually are 3 options MONO/STEREO/SAP
Jun 29, 2010 | Orion STV2763 27" TV
My truflat is speaking spanish on some channels and some channels showing picture and no sound . and the when i turn stereo,mono,and sap pops up.
you have teh audio set in SAP mode. Some nits have the audio mode button on the remote. Otherwise go into the audio setup menu and choose MTS(stereo) or mono.
Apr 28, 2010 | Televison & Video
I have no volume on channels 2 and 7. All other
Your SAP audio function is on. Look on your remote or in the TV menu for SAP or MTS. There are 3 settings, Mono, Stereo, and SAP... set it to Stereo. I hope this was helpful, best wishes.
Mar 28, 2010 | Toshiba 32A33 32" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Lost sound on ABC,NBC,CBS & ESPN classic
on your remote there should be an MTS button, try that because sometimes they broadcast shows in/on mono,stereo or sap. go to those channels and try switching to either mono,stereo or sap. let me know and good luck
Jun 16, 2009 | Emerson Televison & Video
How can I turn off SAP?
if you are using a digital TV is is possible that the frequency is slightly out or you have poor reception.
do a new channel serch first (automatic if you can
and see what happens
sap may reset also if you do this function.
May 05, 2009 | iLO Televison & Video
20" RCA television
Greetings de_on,
Per your owners manual I found you should have an option in your Audio menu labeled MTS. You should be able to adjust the MTS by selecting it and press the + key.
There should be three options under MTS: Stereo, Mono, Auto SAP. You would probably want to select Stereo as Auto SAP will engage the Second Audio Programing which will cause other sound problems.
Hope this helps.
Jon
Go Ahead. Use Us.
May 12, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
748 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
