Question about Marantz SR4002
Marantz SR4002 - blink standby - Marantz SR4002
  • 3 Answers
Pull the power for about 15 minutes, then plug it back in and try it again, if still no work, then you need to get it looked at by marantz...
Posted on Jun 19, 2009
How to set up my speakers
You may have configured your Marantz to use only left and right front speakers.
Apr 25, 2014 | Marantz SR4002
Marrantz sr4002 blinking stand-by button
If you've checked all your speaker connections and there is no short, reset the amp by holding down the "S. Speaker B", "ATT", and "EXIT" buttons for three seconds.
Jan 20, 2013 | Marantz SR4002
Standby button will not turn off
That's why it's stand by button... it is standing by.
Aug 28, 2011 | Marantz SR4002
Marantz sr4002 - Power light blinks but power will not come on. Tried the reset trick and no response. ???
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 22, 2011 | Marantz SR4002
Standby light blinking
if you have the blinking led problem on your SR4002 receiver, it is in protect / safe mode 1- turn on you receiver2- hold 'S speaker B' + 'ATT' + 'exit' buttons at the same time for 3 seconds3- it should turn back on normally
Feb 26, 2011 | Marantz SR4002
Cannot get jamo 250 subwoofer to work via marantz SR4002. Have power but no sound. Also are trying to connect PS3 via HDMI which is no probs however, cannot connect via optical audio
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Nov 02, 2009 | Marantz SR4002
Marantz sr4002 amp standby light flashing
did you ever find a solution? I am having the same issue. rabigelow@gmail.com
Sep 06, 2009 | Marantz SR4002
Power is connected to unit. Flashing standby but will not turn on. Marantz SR4002 receiver.
The unit is in "protect" mode. This means that there is a problem in the final output section. The most common fault is bad output transistors. Expect a parts cost of abput $15-$30 in parts plus the local labor rate for a repair cost.
Dan
Apr 02, 2008 | Audio Players & Recorders
Marantz SR4002 Logo
671 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
