Question about Microsoft Xbox 360 Console
My xbox 360 turns on with 4 green lights but i can not see any picture or sound
It sounds as if you have a connection unhooked or loose somewhere. Double check all audio and video cables are secure and in the correct position. If that doesn't work try troubleshooting by trying a different tv or removing all connections from tv and xbox and re-hooking everything back up.
Posted on Feb 19, 2009
5 Suggested Answers
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
SOURCE: xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Posted on Feb 07, 2009
  • 22 Answers
SOURCE: Xbox 360 not starting up
If you're using HDMI to connect, make sure the TV is on the correct input as the console will 'wait' for a valid signal before powering up fully (on some TV's).
Also check the colour of the Power Adapter when you have powered up the x360.
Here is a link to troubleshoot the power adapter based on the colour of the light on it:
http://support.xbox.com/support/en/us/nxe/hardware/console/setupyourconsole/connecttopowerlist.aspx
Hope this helps.
Posted on Jul 21, 2009
When i turn on x box 360 the green center light appears but the four side lights to not ( no ring). I can open and close the disc on x box but nothing shows up on the tv.
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
Nov 03, 2010 | Microsoft Xbox 360 Console
Ring of light has 4 quadrants flashing green - no picture on TV
Red Lights are a problem for Xbox 360, however green light problems are hard to find, still you can try following steps to check where the problem lies
1) Boot with no HDD and see if that helps.
2) Also remove all your inputs in the back, and reinsert them. Make sure your HDMI/VGA/Compenent input is plugged in correctly.
3) Try switching the output from HD to SD, if you have a HD VGA Cable for your Xbox 360
4) Turn the Xbox 360 off, turn it on with the controller, as it turns on hold the Y button and the Right Trigger, this will put all audio/video settings to default.
If the above given steps do not help, kindly call Microsoft Support and try to get an answer from them to this issue, and if required you may have to send your console for repairs.
Dec 07, 2009 | Microsoft Xbox 360 Console
No picture just sound
ur xbox 360 is in high def turn ur xox 360 with ur controller and hold r trigger and y button together till it turns on. if it dont work than u got the rings of death try this there are fans in the back of ur xbox 360 put a straw on each to stop the fans from spinning wait till it has two red lights than disconected from the back and wait 20 minutes and try it see if it work. if it work this is just a temperary fix.
Jul 02, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 with no picture
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Apr 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
When i turn my xbox 360 on i get a blank screen with no picture or sound
My solution would be to send it to microsoft if it's still under warranty.
Aug 28, 2008 | Microsoft Xbox 360 Console
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
998 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
