Question about Zanussi ZDF490 Electric Double Oven
Recently wired a double oven with isolator switch
I recently wired a double oven with isolator switch but when both ovens on it trips after couple of minutes and the top oven is pretty noisy also any solutions. (i.e) could i have wired incorrectly or is the wrong isolator switch installed etc thanks
  • anoutlaw Feb 20, 2009
    thanks appreciate your early response will check both ovens individually and isolator switch when i gethome from work much appreciated !!
  • 32 Answers
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Posted on Feb 19, 2009
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
When I was using main oven elecric tripped, when the fuse is push back in and oven isolation switch turned back on the electric is constantly tripping only when cooker isolation is turned on, oven element...
Sounds to me to me like a direct short. Hot wire in unit could be touching part of unit. Oven switch if it has one or main board could be shorted. Oven will have to be pulled to check. Slimm possibility weak breaker.
Mar 02, 2011 | New World Ovens
Have A Vulcan VC44gd oven that when you turn it on it trips the breaker. Where should I start.
Blower mtr would be a good start will it sit there until you turn on the power toggle switch.You could isolate the blwer mtr by un wiring directly at mtr.Beware there is a few wires in the junction one set of those wires are for the centrifugal switch(ie the fan has to be runnin for the oven to lite)
Feb 20, 2011 | Vulcan VC44GD Gas Double Oven
I recently bought a new house with fitted kitchen containing a fitted Diplomat double oven. When the power is on but both ovens off the Amber light above the top oven mode selector glows dimly. When I...
I'm not sure its been connected properly, needs checking out by someone who know's what they're doing. Be careful, the fuse doesn't trip for nothing.
Jul 09, 2010 | Ovens
Noisy oven
Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
Apr 25, 2009 | DeLonghi Ovens
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
Zanussi ZDF490 Electric Double Oven Logo
427 people viewed this question
Top Zanussi Ovens Experts
Flipper
Level 1 Expert
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
