Question about IBM ThinkPad T40 2373 Notebook
4 beeps 2373 laptop
Laptop beeps 4 times when it is first turned on
    Problem Solver:
  • 13 Answers
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
Posted on Feb 19, 2009
Why won't my laptop start up?
according to the manual a series of 4 beeps indicates a "RAM read/write error". Do you know how many sticks of memory you have in your laptop?
Feb 18, 2012 | Dell Inspiron M5030 PC Notebook
I get 3 beeps on start up and a continuous dark blank screen
On the IBM Thinkpad 3 long beeps should mean "critical thermal" After it cools down will it start again?
http://www-307.ibm.com/pc/support/site.wss/MIGR-39706.html
Is the fan still working blowing air out the back or side?
Feb 02, 2011 | IBM ThinkPad T40 2373 Notebook
MY laptop beep twice and flag error code Bad CRC1, stop POST task
sounds as if one of your memory modules is defect.
CRC stands for Cyclic Redundancy Check and is a form of checking the memory.
If you have two modules inside, take on out and see what happens.
Best regards
Manfred
Dec 07, 2009 | IBM ThinkPad T20 2647 Notebook
MY LAPTOP DOESN'T START THEIR IS SOME BEEP SOUND WHEN I PRESS POWER BUTTON AND NO DISPLAY WHAT HAPPENED IF THEIR IS ANY PROBLEM IN MOTHER BOARD
This can't be judged with single beep sound. There are different beeps for different problems.
Generally beeps occurs when RAM is disturbed or damaged.
Try to reinsert by opening laptop if you'e  familiar to that or else try to contact System Engineer.
Hope this will be useful Thanks & Regards Nandu :)
Mar 06, 2009 | IBM ThinkPad T40 2373 Notebook
T41 will not start
You could have a memory problem. You RAM could be faulty or just needs reseating.
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
T40 starts bootup, beeps five times and stops.
Probably memory. Check you manual for the POST codes.
Dec 16, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
3,389 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
