Question about Kyocera FS-C5015N Laser Printer
Problems after replacing toner
I have replaced the toner and cleaned the printer yet the printer sill says that it needs to be cleaned,
Can anyone help
  • 163 Answers
You should just have to press the "GO" button to tell the printer that cleaning is complete and the printer will then carry on working once the toner has been added.
Posted on Feb 19, 2009
Hi, I have had my CLX-2160 printer for 3 years now and its started to print with a fade on the left side only and have just under half black ink left. Is it worth changing the black toner cartridge or does...
Hello.
There are two reasons the fade happens. Running out of toner and the drum not responding correctly. The Drum is the unit that transfers the toner to the paper. if it gets damaged or dirty inconsistent print is usually the result. Try taking the toner out, shaking it and replacing it to see if it affects the print quality. if it does not price a replacement drum and toner, compare it to the price of a new printer and this will answer the second part of your question!!!
I hope this helps Regards GM
May 27, 2011 | Samsung CLX-2160N All-In-One Printer
After I changed a replacement toner cartridge. I had few pages print out Okay but afterward, Vertical white strip on the center of page appeared. I don't know how to fix it.
3 things can cause these problems
Lack of toner or faulty toner cartridge.- shake cartridge and try again Defective fuser - replace fuser Contamination in the laser path -. 1.)Clean the laser path. (Remove the laser/scanner assembly and clean the lens.).2.) Replace the laser/scanner assembly
Mar 07, 2011 | Canon PC150 Personal Copier (PC 150,...
Wont print in black
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Brother DCP-110C All-In-One InkJet Printer
Streaks on my laserjet 3800
Hello sir; Remove the transfer belt unit, at the end of the unit you sill find cleaning unit, vaccunm it up, if neccesary, replace cleaning blade .
Oct 21, 2009 | HP LaserJet 3800 Printer
Dark lines appear on each page I print on the printer. I have cleaned every roller, dumped the old toner and added new toner.
Are the lines vertical or horizontal?
vertical lines can be caused by several things.
Since you said that cleaned the rollers, then here are other options
1: Most common is a bad toner cartridge.
2: try cleaning the fuser entrance guide.
3: could be a defective formatter - formatter replacement the fix.
4: worn fuser. fuser replacement is the fix.
horizontal lines are probably repetitive down the page, and are usually caused by a defective toner cartridge or fuser assembly. occasionaly a transfer roller will cause it as well.
Toner loves to get baked onto the fuser and cause all kinds of print problems. Not much you can do but to replace the fuser when this happens.
Oct 17, 2009 | OKI OL 400e Led Printer
Cleaning page
Ideally just replace the toner cartridge. But if fairly new, just clean the loose toner off from the old cartridge's printing surface by swabbing it as you manually turn the drum. If while doing this you notice black burned into the glassy surface of the toner cartridge or scars along the surface you'll just have to replace it. Happens once in a while, especially with refurbished cartridges.
May 08, 2008 | Lexmark T520 Laser Printer
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Lexmark C510
try to clean the toner from tissue paper or if you want good quality you replace the toner or copen the cover of printer toner and clean is there any ink powder is there. bye
Sep 21, 2007 | Lexmark C510 Laser Printer
Kyocera FS-C5015N Laser Printer Logo
1,079 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
