Question about Intel Motherboard
How can I understand the jumpering system of a motherboard
Things like discharging the bios, clearing the password, clocking the motherboard or processor, setting the audio devices of the system etc. I am a student undergoing a three month intensive course in computer maintainance.
  • 30 Answers
Most motherboards dont have jumpers nowadays,( their all into sweatshirts) if they do, the usage of the jumper is described in the manual, & if u aint got one of them sqwint at the board, theres info on there., try manufacture website, but they do remove old manuals & drivers.
Dispite my words, Always will a CMOS have the provision to be shorted
Posted on Feb 19, 2009
Passworld clear for Bios
Im afraid you have no choice but to restart your entire BIO's
They're two ways to do this, both include opening the case
  1. Remove the BIO's jumper and restart then reinsert
  2. Remove the CMOS battery and reinsert
Only reinsert when you have discharged all static electricity and the computer is powered off
Good luck
-Ryan
Mar 06, 2011 | Computers & Internet
Where can I find my jumper to reset my bio password on my hp computer?
On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual cmos battery.
By the processor - Some manufactures will place the jumpers by the processor of the computer.
Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
hope this helps
Jan 10, 2011 | Computers & Internet
Clearing bios password
Many RTC
Dec 29, 2010 | Toshiba Satellite A20-S207 Notebook
Dell inspiron 1545 has authentication system password ..tried removing battery cannot get pass it
The aim is to reset the BIOS so that data concerning passwords are cleared out. This is done by moving a jumper on the motherboard.( The biggest challenge is to find it).
Note that: This procedure also resets the BIOS settings. If you have made changes, this manipulation will reset these features to default.
  • Step 1: Turn off your PC and unplug the power cable and open your system unit. Touch the chassis of the casing with a metallic object to discharge static electricity.
  • Step 2: Check the documentation for your motherboard to locate the position of the jumper, that reset the BIOS. If you don't have any manual, look on your motherboard one of the following tag: CLR BIOS, CLEAR BIOS, CLR CMOS, CLEAR CMOS, RESET BIOS or RESET CMOS. It is usually near the CMOS battery on the motherboard.
  • Step 3: Find the jumper on your motherboard reset it. It is usually close to the battery.
If the jumper is on 3-connector pins, place it on the middle and the initially uncovered pins.
Wait for some time and put the jumper in its original position (PIN1-PIN2).
If the jumper is on a 2-connector pins and that it holds on a single pin, place it on both, wait one second and then return it to its original position.
  • Step 4: Power up and start your PC: the password has disappeared.
Dec 04, 2010 | Dell Inspiron 1545 Notebook
Bios asdin password forget iam not abul to oparate system
Resetting the BIOS Password using HardwareIf you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it
Jun 19, 2010 | Toshiba Satellite A305-S6853 Notebook
Don't reset password BIOS HP DC7100
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
I want to buy a computer at a pawn shop but the bios password is locked. is it easy to unlock?
Hello there :
if you first shut down the computer and remove the side panel and get to the cmos battery and remove it for 5 min than replace the battery and reboot the computer this will bypass the cmos password. than just go into bios and set your own password ok?
best regards mike
Jul 31, 2009 | Acer Computers & Internet
How do I reset my lost bios password for Dell Precision M70
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
