Question about Sharp 65DR650 65" Rear Projection Television
65dr650 color wheel
Looking for a instructions on replacing the color wheel, sharp cannot provide me with their own manual. i know its located in the tv but where,
  • Anonymous Apr 15, 2009
    i have the same problem
It is in case next to the lamp. Its thin cable sticks out from the case. You will to open the back panel of the TV, check for cables, remove screws for the base on the right, then pull out the base out. You will have to be very careful removing screws and gentle when replace the color wheel. Hope this helps.
Posted on May 21, 2009
MY 65DR650 REAR PROJECTION TV WILL NOT COME ON. IT MAKES A HUMMING SOUND LIKE A JET BUT WILL NOT COME ON I HAD A TV REPAIRMAN LOOK AT IT AND HE SAID THE COLOR WHEEL IS GOING OUT AND NOW 3 WEEKS LATER IT...
If you are comfortable - you can try taking the color wheel out of the tv. Pop the motor apart and clean all the residue on the bearing/spindle. Then lubricate and put it back together. Search on google for how to do this.
There is a company that replaces the motor. Search on ebay for them.
Mar 07, 2011 | Sharp 65DR650 65" Rear Projection...
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
My Sharp 65DR650 went out today, the screen got pixelated. Turned it off and back on, now Red is the main color, everything is a shade of red, tryied different inputs HDMI, COMP 1-2 and AVI all are red. I...
That humming noise was your color wheel going bad. It is part of the optical engine. I am not sure if you can replace it separately. In any case this is complicated and expensive repair.
Mar 10, 2010 | Sharp 65DR650 65" Rear Projection...
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
Sharp 65dr650 color wheel noise.
I saw the same post, discount-merchant.com sells it for 69.99 but as I found out it is the WRONG one. Not even close and I'm annoyed he obviously never tried it himself. I bought a sharp replacement off of ebay but it died after 2 weeks, no refund. The Samsung model number that does not work is BP96-01579A. Maybe there is a samsung model that works but this was not it.
Mar 26, 2009 | Sharp 56DR650 Television
Sharp 65dr650 rear projection tv makes loud nois while its on
Looks like we all got screwed with this TV. Mine just started after 2 years and now it's getting louder. I think I rather call my lawyer than Tech. This product is NOT build properly and someone should let the company know about it.
Jan 04, 2008 | Sharp 65DR650 65" Rear Projection...
Sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Oct 31, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 65DR650 65" Rear Projection Television Logo
409 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
